Spigot rings
tinka Jul 5, 2012
  1. tinka
    tinka Member
    66
  2. N8
    17,163
    718
    Just get genuine ones, your driving a B8! But there is nothing wrong with spigot rings, I have them on my A6 rims as they are 66.6
  3. tinka
    tinka Member
    66
    The genuine ones are around 2k I think, I'll have another look around, cant seem to find any on e-bay, unless I missed them.
  4. N8
    17,163
    718
    You can pick them up for less than £2k.
  5. Pyeman
    Pyeman Member VCDS Map User quattro Audi A6 Audi Avant Owner Group TDi
    183
    20
    They are ok but I to would go and buy the real thing.
    You should give ebay germany a look too.
  6. longp2
    longp2 Active Member
    321
    40
    Have you considered selling your 18s? If so then I'd be interested in them to use on my S4 as winters.
  7. tinka
    tinka Member
    66
    Thanks all, I'll keep looking, I think I'll stick to the correct centre bore, found some others with the correct bore.
    longp2, I will sell them, no point keeping hold of them, I'll let you know when I get around to changing.
  8. longp2
    321
    40
    Thanks mate. Forgot to mention that i had a quote for replica Audi wheels with winter tyres on from Revolution in gateshead and they came in well under OEMs. I know the quality may not be quite as good but they have the correct bore, pcd, et etc so do not need to have spigots fitted.
  9. tinka
    tinka Member
    66
    Thanks mate, I've found a place that does them, but deciding on the right offset is driving me mad, I'm going for 19/8.5 but the offsets available are-et 32/35/45, I think the first two may be a bit too much extending 21 & 18mm and 45 will extend 8mm more than the standard wheels, I just can't make my mind up.
    If I'm right the standard s4 wheels similar to the original post are 19/8.5 et43 does that sound right, been browsing the show threads on Audizine all bleedin day.
  10. longp2
    321
    40
    I'm sure the offset on my 19s is et43. I'll check when i get home on wednesday
