Speedy's hunt for missing horses
Speedy Steve Nov 13, 2012
  1. Speedy Steve
    Speedy Steve Active Member
    1,258
    Well after putting the S3 on Bills dyno for the first time since he mapped it with the hybid some 3 years ago it turns out ive lost over 40hp but gained 50lbft which has got me slightly worried. Whats strange is Liquid said 333hp and 320lbft yet I only got 272bhp and 301lbft. It looks like its boosting fine and holds 24psi perfectly. So now starts the job of a few more upgrades and the hunt for where my ponies have gone.
    Plans:
    Wellycooler (ordered)
    TFSI coil pack
    New Plugs
    Oil Change
    V3 Relentless Manifold
    Now this isnt going to be a quick job as i have my wedding in Feb. Plan is for Bill to weld pipes on to wellycooler so i dont loose my day lights (broken head light switch has fogs on all time)
    Other than these bits anything anybody can think of i should change or do?
  2. badger5
    9,321
    1,891
    map adjustments.. a lots changed since we first did yours..
  3. Speedy Steve
    1,258
    That is true bill but it does seem strange that ive lost bhp but gained lbft. It all seams to be in the higer rev range as well.
  4. superkarl
    superkarl MAN OF STEEL
    9,333
    2,339
    id be happy with that change!
    i thought when you'd posted in the dyno thread you'd LOST 50lbs torque.
    id rather have torque than horsepower.
    do you have an 80mm tip?
    consider an inlet mani of some description if you have the dosh.
  5. beachbuggy
    beachbuggy Well-Known Member
    1,931
    201
    doesn't liquid gauge just convert maf to bhp?
  6. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,183
    Meth :)
  7. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Yes i believe it does..
  8. Speedy Steve
    1,258
    Got Meth! used nearly a full tank in the trip to bills and back lol
  9. Speedy Steve
    1,258
    Wellycooler has just turned up. I only ordered it sunday night after getting back from Bills
  10. s3dave
    10,110
    736
    I would get an uprated Actuator Steve... My CR one was blowing/leaking
  11. Speedy Steve
    1,258
    Man this things huge and bloody cold!
  12. badger5
    9,321
    1,891
    its not struggling for boost...
    if anythings its higher than I would set knowing what I know now, some 3 years on.
    1bar actuator on steve's, unported, so no doubt creep in there also..
    wmi when not set up optimally can hurt power... depending on nozzle size, pressure setpoints etc....
  13. badger5
    9,321
    1,891
    TT from last week we made fmic setup on... same toyo cooler
  14. superkarl
    9,333
    2,339
    snap
    just about keeps the grills:
    i imagine you are after a very much oem look steve?
  15. Speedy Steve
    1,258
    Well my car looks far from OEM but yes id like to keep the fogs
  16. Speedy Steve
    1,258
    Removal tool for my wheel bolts turned up this morning to. So i can try and get the fronts off after the nightmare at Bills of snapping the old one. Remembered it wasnt me that last did them but the garage that changed the steering rack gator and drop links that they failed on its last MOT so will be going back and having a few words with them at some point
  17. Speedy Steve
    1,258
    Hum nozzle size ill have to check which nozzle i fitted when i get back. Maybe thats part of my problem.
  18. Speedy Steve
    1,258
    looking in the bag of spare nozzles it looks like i have the middle one in so will fit the smaller one at some point soon
  19. Speedy Steve
    1,258
    Just got back from work and thought id drill out and tap the bit that broke in the wheel bolt. Got all the tools out and got ready. Guess what........
    It had fallen out. Bargin! so now out comes the impact gun to undo the bolts and copper grease them
    scoobyra likes this.
  20. Speedy Steve
    1,258
    No joy with my Impact gun so tomorrow when i get home I'll go back to the garage that did them up so bloody tight
  21. badger5
    9,321
    1,891
    smack them about the head with the torque wrench they clearly dont use!
  22. Speedy Steve
    1,258
    Well i took the S3 back to the garage that had the front wheels off and the guys there were very nice and managed to get the bolts undone. His first words when trying were "F**k me which C**T did these up?" which i laughed my ass of to. But there now loose and greased up so all good now back to the hunt for my missing power
    Plans for this weekend are trying the smallest WMI nozzle and see if i can feel any difference in power.
  23. Welly
    Welly VX220 SC Driver :)
    10,696
    127
    I see your V1 and I raise you a V2.
    Also bloody cold!
    S3quatt likes this.
  24. Speedy Steve
    1,258
    LMAO that is going to be an interesting fit! good luck
  25. S3quatt
    S3quatt Flat Oot like a ducks Foot VCDS Map User
    652
    58
    Like the monkeys at my local tyre place...
    They always use a torque wrench... AFTER the rattle gun!
  26. S3quatt
    652
    58
    Judging by the pic, & if you're old enough to remember it. Here's one I made earlier Blue Peter style with some bottles, glue & sticky backed plastic!
  27. Speedy Steve
    1,258
    Well today i fitted the smaller nozzle then had the wheels off to clean them and then cleaned the car. After that i took it out for a little spin to just clean the brakes up and managed this
    Now thats 7bhp more than ive seen before through the liquid. The question is will it reproduce it on the rollers????
  28. badger5
    9,321
    1,891
    no
    Speedy Steve likes this.
  29. Prawn
    11,360
    3,203
    :laugh::laugh::laugh:
  30. Andrew@A.L.D
    3,872
    609
  31. Speedy Steve
    1,258
    No its a Stock AMK head. I very much laugh at the liquid value but to see an increase by changing the wmi nozzle is always a bonus.
    Bill i expect that after its been to you. lol
  32. badger5
    9,321
    1,891
    has anyone ever correlated or confirmed how liqui comes up with its power measurement?
    is it from block 120 torque on ecu or airflow divide by a constant?
    anyone?
  33. Speedy Steve
    1,258
    I have a feeling its just off the MAF
  34. Speedy Steve
    1,258
    Just looked on Racediagnostics web site and it can be done either way but defult is off maf
  35. s3dave
    10,110
    736
    There are two modes. the default is maf over 0.8, or an alternate mode can be selected which calculates bhp from the engine ecu torque signal and the rpm.
  36. badger5
    9,321
    1,891
    worth comparing what its torque model looks like as a comparison
    airflow being somewhat misleading.... to measured power
  37. Speedy Steve
    1,258
    I will give it a try next time my Private road is free
  38. Speedy Steve
    1,258
    Well the manifold is now ordered. cant wait for it to turn up ad be a paper weight at work until i can get it all fitted
  39. Speedy Steve
    1,258
    Having second thoughts about keeping the fog lights on the bumper with the wellycooler
  40. Dani_B19
    8,995
    325
    Why mate? Ive kept my fog lights.
