Speedo driving me mad!
Super_stylin Jun 3, 2012
  1. Super_stylin
    Super_stylin New Member
    Got a 2001 1.8t Quattro. Seems to be when it's warm outside and dry my speedo and fuel gauge stop working. The speedo stays on zero and the gauge goes down when accelerating. It's rained today and gone cold, guess what speedo has come back on working fine! Any help would be great!
  2. Mav190sline
    Mav190sline Active Member
    195
    27
    Ever thought about moving to the south pole lol
  3. Super_stylin
    Ha ha ha. Please guys any advice welcome
  4. demus
    demus Fire in the hole..
    355
    19
    Could be an electrical connection inside somewhere, my central locking is funny when its hot outside, it will unlock the rear doors twice, and then try again when you turn the ignition on!! If its cool its fine...
  5. Turkster
    Turkster Bro.Paul 2.5TDI Quattro Sport
    2,797
    47
    change the pod
  6. quattro tony
    quattro tony Member
    167
    Could be the heat affecting the pod internals?, have you managed to scan the instrument cluster? might be worth doing first
  7. Super_stylin
    Not scanned no; it's just strange that heat and wet weather can effect it that's why I thought something underneath the car.
  8. pauldazzle
    pauldazzle Well-Known Member
    1,131
    81
    Mk1 Skoda Octavia's suffer the same problem that you describe, & it's usually caused by dry solder joints on the 2 voltage regulators in the dash. It's quite possible you have the same problem as the Audi dash is very similar. Sometimes reseating the dash connectors can fix the problem too, but most of the time it's a dry joint.
  9. Iceash
    Iceash Member
    391
    10
    I was thinking dry joint also, the rain will be acting as a heat sink. So ambient will drop allowing the car to contract slightly including all the plastics and so forth. opposite with the heat, allowing the dry joint to fail. Could be worth speaking with an auto sparky, might be able to replace it for you but I'd be you'd be looking at around 150ish smackers.
  10. pauldazzle
    1,131
    81
  11. Super_stylin
    Cheers guys I'll check into this
