Speed warning -please make it stop !!!
Discussion in 'A3/S3/Sportback (8P Chassis)' started by Mark_N, Mar 27, 2005.
  1. Mark_N
    Mark_N Member
    Mar 21, 2005
    250
    Changed the clock in the car while on the move this morning...suddenly after doing it everytime I go over 35mph I get speed warning in the dash and a beep...EVERY BLOODY 10 SECONDS when I go over 35!!
    Surely you can't even switch on the speed warning from simply turning the small stalk coming out of the clock?
    It's a '04 with the computer display...
    HELP!! /ubbthreads/images/graemlins/noidea.gif
  2. Advert Guest Advertisement
  3. scoTTy
    scoTTy Active Member
    Jan 2, 2003
    1,962
    I don't know what car you have but I'm sure it's covered in the manual. It was in both the TT and S4 manuals.
  4. Mark_N
    Mark_N Member
    Mar 21, 2005
    250
    A3 TDI sport...I haven't had time to look in manual, in work til 6.
    Just was trying to find out if it's even a turning of that stalk that turns the warning on so I would know if I could've done it or if it's a fault,
  5. marriedblonde
    marriedblonde Moderator
    Dec 6, 2004
    4,371
    Mark,
    If it's the speed warninng 1 thenit resets itself when you turn the ignition off. If it's speed warning 2 thats coming up you can turn it off by entering the DIS menu (press the reset button once quickly and the menu will appear. Then just scroll through til you find it)
    J.
  6. Mark_N
    Mark_N Member
    Mar 21, 2005
    250
    Yep was speed warning 1 - good to know it's gone so!
  7. DAF
    DAF Member
    May 20, 2004
    156
    If you press the stalk in once, the same stalk that adjusts the time it will bring up a yellow speed sign in a circle. Once this comes up press the stalk again and it should then show two yellow lines through the circle that should turn it off.
  8. DAF
    DAF Member
    May 20, 2004
    156
    Too late again sorry for being slow off the mark chaps. /ubbthreads/images/graemlins/shutup.gif
