spec list of 2.0t vs 3.0 tdi
moggytom May 8, 2013
  1. moggytom
    moggytom Member
    41
    searched thru 100 pages now and I cant seem to find a spec list for the cars e.g what mpgs they both get total power and torque and what they can have after a remap [HR][/HR] I know the 2.0t has the oil pick up pipe problem does the 3.0tdi have any problems like this ?? [HR][/HR] insurance is cheaper on the tdi so might end up with one of them but never had an auto so what is triptronic ? does it have flappy paddles on the steering wheel ?[HR][/HR] thanks tom
  2. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator TFSI Owners Group Team V6 Gold Supporter Team Tornado Audi S4 quattro Black Edition s tronic
    8,398
    2,937
    Send me a PM with your email address and I'll send you a PDF of the 2007 A4 range brochure.
  3. A4_MaJiK
    A4_MaJiK Azeem
    924
    109
    43
    Could you send one my way as well Jeff?
  4. jdp1962
    8,398
    2,937
    Done.
    A4_MaJiK likes this.
  5. Molnboman
    Molnboman Well-Known Member
    1,338
    193
  6. moggytom
    moggytom Member
    41
    thanks :) il have a look over it, pm sent jdp196
  7. chrisa4quat
    chrisa4quat Active Member
    970
    Oil pump issues on 2.0t. 3.0 has intake manifolds and throttle bodies mainly
  8. V6 Quatt
    V6 Quatt Well-Known Member
    1,248
    439
    And me
  9. jdp1962
    8,398
    2,937
    Do you mean you'd like a copy too?
    If so, PM me your email address & I'll send it right over.
  10. moggytom
    moggytom Member
    41
    any link to more info on the intake issues ?
  11. Mr-C
    Mr-C Active Member
    234
    Is Google broken
  12. jdp1962
    8,398
    2,937
    There are quite a lot of threads on this (I've even contributed a couple myself) which a search should throw up for you. Essentially; the inlet manifolds on 3.0TDi models have swirl flaps inside, mounted on spindles which are attached by little drop links to electric motors mounted on the outside of the manifold. The mechanism wears out prematurely so the linkages become loose and sloppy (sometimes the drop links become detached at one end - usually the spindle end). The looseness causes the engine management system to detect an error in the amount of movement in the flaps, and the engine warning light comes on. This causes a slight drop off in performance but not by very much. However, the car will fail an MOT.
    Audi's official solution is to replace the entire manifold, flap and motor assembly, at a cost of around £700 per bank. A less drastic solution is to have the mechanism repaired and modified (I had that done on mine by Fontain, the indie Audi specialist from whom I bought the car) at a cost of £225 per bank. If you are mechanically gifted yourself (I am not) I think I might have a link to a repair guide on my home pc. The least costly option is to leave the faulty linkage as it is, and have the fault code mapped out to that the engine management system just ignores it.
    As to your question about the auto box (note; it's Tiptronic, not Triptronic), the steering wheel mounted paddle switches were an optional extra, so some will have the, some won't. As with all things Audi, they can be retro-fitted. We have a forum member - NHN - who does this for a living.
    Hope that helps.
    Jeff.
