Spec/Code listing
DarkBunny Jul 18, 2013
  1. DarkBunny
    DarkBunny Active Member Team Sprint Audi S3
    497
    112
    43
    Had a quick search, but as there are a number of topics I can't seem to find the area I'm looking for...
    Just wondered if there was a section which detailed the standard specs of each car (ie. engine code, chassis code, basic equipment etc)?
    Just so that I refer the right models/numbers when posting :o.k:
  2. RobbieWebs
    RobbieWebs Well-Known Member VCDS Map User
    1,031
    249
    U mean like a brochure of A3's or something from past to present?
    If this is the case have a search in google if found a few on there.
    If not this then what u after as that's a very open ended question lol :)
  3. DarkBunny
    497
    112
    43
    It could be I guess. It's an odd one really, as I don't know my engine code, I posted in the wrong section cos I didn't know the chassis number, don't know what's standard and what's optional - the list goes on :think: !!
  4. SootySport
    SootySport Well-Known Member Team Silver
    2,811
    748
    Have a look in your Audi Service Schedule book, its the book with your service records in. Inside the front cover there is a sticker with all the Car spec. option codes, engine code etc. chassis code is the top line. Engine code is the 5th. line down. The same sticker is also in the the boot under the carpet by the spare wheel well.
  5. RobbieWebs
    1,031
    249
    What year of car are u looking for the details for?
  6. DarkBunny
    497
    112
    43
    Ta!
  7. DarkBunny
    497
    112
    43
    2007 S Line TDi Quattro
  8. Cozza McA
    Cozza McA Crunching The Gears VCDS Map User
    410
    74
  9. DarkBunny
    497
    112
    43
  10. DarkBunny
    497
    112
    43
    I typed them all in and it didn't work - any other tips?
  11. fangio
    fangio Well-Known Member
    1,497
    179
    Did you follow the instructions? It works perfectly when you do!
    There are no Os, only zeros.:icon_thumright:
  12. DarkBunny
    497
    112
    43
    I'll change the Os to zeros and try again
  13. fangio
    1,497
    179
    Did you put semi-colons between each group of letters?
  14. DarkBunny
    497
    112
    43
    Yes, but when re-reading them I'd put a ' inbetween a set too!
  15. fangio
    1,497
    179
    Ah, that ubiquitous apostrophe! So it worked?
  16. DarkBunny
    497
    112
    43
    It certainly did thanks!
