Speaker issues
Cookie0125 Aug 11, 2010
  1. Cookie0125
    Cookie0125 New Member
    25
    Hello all,
    I recently bought an aftermarket headunit which has been wired up correctly with all the relevant adaptors to my '97 A3 non-Bose, however, the driver's side foot well speaker isn't working at all.
    The passenger side works fine and the rear and subwoofer work aswell, even the driver's side mini speaker(next to the door handler) is working fine its just the footwell speaker.
    So I thought the speaker must have blown and bought a replacement Audi A3 speaker and still exactly the same problem when I fitted the new speaker. Any ideas on what the problem might be? Any suggestions on potential fixes?
  2. Bignick
    Bignick Member
    165
    I would check your conections on the back of the head unit.
  3. Cookie0125
    25
    I have and it all seems to be fine, I've tried another headunit which I had spare and even that has the same problem.
    I can't think what else it could be?
  4. jimmp
    jimmp Member
    194
    Right well, this is a peach of a problem!
    What to do is get an AA battery and connect it over the (+) and (-) terminals of the ISO connector (with the head unit removed of course) you should hear a large crack from both the door speakers, if you only get the tweeter (next to the handle) then there is something wrong further on. In fact it'll be in the door.
    The Haynes shows the wiring to the door as red and & brown/red going through connector T10r on the door on pins 1 & 5. If you can hear the tweeter working then the signal is reaching the door through this connector. Inside the door it connects to the midrange (door pocket) speaker first as red/white & brown/white and then onto the tweeter. You need to concentrate on the midrange connections- is there a crossover??
    JimP
  5. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    If the tweeter works then the wiring and connection to the HU is fine as both tweeter and mid driver run off the same wiring. The wiring goes to the mid then a piggyback runs from the mid via an inline capacitor to the tweeter (to high pass the signal). The problem has to be the speaker (measure it via a multimeter on the ohms setting, should be 4 ohms or do the battery trick detailed above). It's not impossible that the replacement is also blown if an ebay jobbie. Did the speaker work before with the original HU?
  6. DGT
    DGT New Member
    21
    could be broken wires, mine were fecked on both doors (02 B6)
    *edit*
  7. AndyMac
    9,832
    46
    As said can't be the wiring if the tweeter works, they run off the same cable!
  8. DGT
    DGT New Member
    21
    ^^oh aye..sorry
  9. rlc1985
    rlc1985 top gear
    124
    I have the same problem with my drivers door speaker, tweeters fine.
    It sounds like its blown untill you turn it up load. I removed the door panel off took it in the house and connected the wires to my stereo system in the house and the mid range and tweeter both worked fine. So maybe it is some wiring at the back of the face just not got the right keys to take it off yet and have a look.
