Speaker info ?
joinerman Feb 7, 2014
  1. joinerman
    joinerman Well-Known Member
    9,750
    298
    The front passenger side speaker has started making an annoying noise, like the cone has split, driving me nuts, is a replacement audi only ? haven't been able to get the card off yet ( when I find out how ) to have a look, been a bit wet.
  2. Giosabcsl
    Giosabcsl Active Member Audi A4 saloon
    853
    156
    43
    The cards are not that bad to take off thou the clips do tend to break when you pop the door car off which if your car is around 2004-2006 most likely you will break about 2 or 3 but this is normal as they not really meant to be removed.
    DIY: B6 A4 Window Regulator & Motor Replacement
    The above link will give you a idea on how to get to what you are after. AS for speaker replacement I am not sure but I know when I replaced a window regulator recently the audi speakers have there own type of clip in pin so I am not sure if you can cut the wires or buy a converter.
    Hope the link helps.
    The clips btw are like 5p ea. So dont stress.
  3. joinerman
    9,750
    298
    Thanks, great link.
