Speaker Cover Replacement
DMAGEE Sep 14, 2007
  1. DMAGEE
    DMAGEE New Member
    Due to unseen circumstances, the speaker cover on my rear driver's side door is badly damaged. Could some body tell me if this is expensive to replace and how they are actually fixed to the door ??
    I have heard some reports of them being plastic welded and also the possibiliy of being held on by rivets !!
    Would appreciate if someone could possibly shed some light on this.....
    Thanks.
  2. jase0851
    jase0851 Member
    789
    the grills are part of the doorcard,they are actually plastic welded on, u could try to fix some new ones on but they will probs come loose with base vibration ?
  3. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    You can get replacements from thedealer for around £8, but you then need to hotmelt glue them in place from the back once you've removed the knackered one.
    Quite easy really, just a little messy.
  4. Issac Hunt
    1,162
    Yes they are plastic welded on but you can still change them, they are available from Audi as a seperate part (under £10 IIRC) You will need to remove the door card to fit it, just melt the securing plugs into place with a soldering iron. Should take no more than 30 minutes to change, I did one afew months ago for a friend's B7 A4 when it was damaged.
  5. DMAGEE
    DMAGEE New Member
    Many thanks for your replies...much appreciated !!
  6. AndyMac
    9,832
    46
    While you're buying the grille, also ensure you buy some of the plastic pop fasteners for the door card as these are designed to break when you remove it. You'll need 4 or 5 and they're only 18p each.
