spark plugs....???????.....
smudgy57 Jul 11, 2004
  1. smudgy57
    smudgy57 Member
    71
    does anyone know what spark plugs come in an s3? are good ones? is it an idea to replace them with better ones? and what ones? will it effect my 3 year warranty? (sorry alot of questions there lol) /ubbthreads/images/graemlins/crazy.gif
  2. JamesA3
    JamesA3 Member
    238
    they don't use spark plugs they use coil packs
  3. Mike.M
    Mike.M Well-Known Member
    2,510
    170
    The coil packs sit on top of the spark plugs mate.
    The coil packs replace the old dissy and leads.
    With reference to what spark plugs Audi use.........they are NGK's. I was looking into getting some BOSCH super 4's but they do not seem to make them for the S3/TT, so going to replace them with new OE NGK Audi ones.
  4. HTC
    HTC Active Member
    3,428
    9
    They make super 4's for the A3 turbo. Strange why they wouldn't do 'em for the S3.
    Anyways, I've never seen the point in super 4's. You can only spark to one electrode at a time.
  5. Drill
    Drill Member
    928
    Denso Iridium IK20 (or 22's for chipped folks/S3 people) work well. I use the IK22's on my TQ /ubbthreads/images/graemlins/grin.gif But they're a bit pricier than std /ubbthreads/images/graemlins/smile_smoking.gif
    I get mine from Neuspeed in the States (Here) But I'm sure there's a UK distributor for those interested. /ubbthreads/images/graemlins/cool.gif
    /ubbthreads/images/graemlins/beerchug.gif
  6. Mike.M
    2,510
    170
    I found super 4's great on previous cars. Noticed an increase in engine response/pickup and fuel economy increase too compared to standard plugs.
    The S3 plugs have a weird sharp point to the tip.........not seen a plug like that before as they usually have a flat cap to the tips.
    Will look into those plugs Drill......cheers!
  7. Drill
    Drill Member
    928
    The narrower point supposedly generates a stronger spark /ubbthreads/images/graemlins/crazy.gif More concentrated or something /ubbthreads/images/graemlins/confused.gif And the stronger spark helps ensure more fuel is burnt, making everything more efficient and stuff /ubbthreads/images/graemlins/goofy.gif
    /ubbthreads/images/graemlins/grin.gif /ubbthreads/images/graemlins/beerchug.gif
  8. Mike.M
    2,510
    170
    Wealth of knowledge
    /ubbthreads/images/graemlins/lol.gif /ubbthreads/images/graemlins/goofy.gif /ubbthreads/images/graemlins/idea.gif
  9. HTC
    HTC Active Member
    3,428
    9
    Probably something to do with the heat rating too?
  10. Banwell
    Banwell previously LeeS3
    393
    the original platinum NGK are the ones.
    Interestingly spark-plugs.co.uk have then for a £10 each but vagparts want £32 each!! Is this a mistake?
    I am sure mine need changing fuel econ down & sometimes fails to fire up on ignition.. Chipped cars should have them replaced every 20k.
  11. HTC
    HTC Active Member
    3,428
    9
    I'll have to remember that link. Thanks for that. Mine haven't been changed for a while. Best get round to it!
  12. JamesA3
    JamesA3 Member
    238
    [ QUOTE ]
    [/ QUOTE ]
    Doh! what a tw4t, thanks for putting me right
  13. Mike.M
    2,510
    170
    No problem James M /ubbthreads/images/graemlins/tongue.gif
    I wonder what Audi charge for a set of the OE NGK's?
    I have been finding my Audi dealer quite reasonable recently
  14. HTC
    HTC Active Member
    3,428
    9
    Generally items that can be bought elswhere aren't to expensive....brake pads/discs for example.
    Stuff you can only get from Audi is usually expensive.
  15. Banwell
    393
    also check sapmotorparts.co.uk for check oem parts - discs and pads are really cheap. Manufactured by hazel quiton..
  16. Khufu
    Khufu Well-Known Member
    5,704
    31
    I've got the Denso Uridium ones too. They are expensive but last for 80K miles IIRC.
  17. smudgy57
    smudgy57 Member
    71
    thanks lads there is a whole load of info there to chew over!! now secondly how easy/hard is it to fit them? any diagrams would be even better. funny enough it was one of my coils that went about a month ago on the m25. pulled over on hard shoulder and within 45 mins audi engineer pulled up and just changed all four. it was to busy to get the laptop out and start doing a diagnostic test. must admit i was very impressed with the service coz my car is still under warranty(just) i did not pay a penny or even sign anything. when it comes to service audi do come up on top for that!! not like bmw, merc, etc. now after all that coz coils are still quite new is it worth changing them after all???? stupid me did'nt relize that coils were the equivelent to spark plugs DOH!! any way cheers lads
  18. peteA3tdi
    peteA3tdi Member
    408
    [ QUOTE ]
    [/ QUOTE ]
    coil pack are not the equivelent of spark plugs they replace dizzys and plug leads
    multi tip plugs are for hi compression n/a engines
    1.8t's and S3's need platium plugs for a stronger spark
  19. paulbinks
    paulbinks Member
    56
    Try german/french and swedish or GSF for plugs as they do original fit bosch plugs very cheap but you may need to ask for TT 225 bhp plugs as S3 plugs may not be listed on there data base of parts,dealer fitted them for me at 40000 service and sourcing your own parts saves a [censored] load of cash when dealing with audi stealers.
  20. neil.c
    neil.c Senior
    568
    I had my plugs changed last service they were not particularly expensive as I recall.
  21. Ess_Three
    Ess_Three Active Member
    5,383
    [ QUOTE ]
    [/ QUOTE ]
    Same here...
    IK22s are a heat range cooler and more suitable for running 1.8+ bar boost on a VERY hot engine!
    They work well...but to be honest, no better than standard.
    I guess it's good insurance though, running a cooler heat range plug.
  22. Which are the better plugs to go for on the S3..
    The Iridium or the platinum.. /ubbthreads/images/graemlins/confused.gif
    I've been told to go for the NGK Iridium plugs rather then the Denso Iridium ones, by my local supplier.. Says they last alot longer and more reliable..
    Mine car has done 31,000 miles now.. Think i should change them..
  23. Ess_Three
    5,383
    The NGKs will be fine.
    The Denso Iridium IK22s are great for highly stressed, very hot engines running lots of boost. That's the only reason I've got them in.
  24. Drill
    Drill Member
    928
    Hey Glen, do you remember how many miles the Iridium's are supposed to last? /ubbthreads/images/graemlins/crazy.gif
  25. Sorry to interrupt..
    They are supposed to last 80,000 miles.. Well so they say..
  26. David_Moon
    David_Moon Member
    43
  27. jojo
    28,944
    3,598
