Spark plug stuck in RS6 V10
Discussion in 'RS6 Forum' started by scoobydoo1098, Nov 10, 2013.
  1. scoobydoo1098
    scoobydoo1098 New Member
    Nov 10, 2013
    Has anyone had similar issue and if so, how did you resolve it?Audi dealership claiming this could cost £2k to fix
  2. Advert Guest Advertisement
  3. Rodders.
    Rodders. Active Member
    Oct 21, 2013
    183
    Keep applying penetrating oil over a few days. Should release then. Had it with a bleed nipple on a caliper. The bolt was almost rouding i was having to try so hard to undo it. I kept spraying it with penetrating oil all week and then it undid. Dont use WD40, use proper penetrating oil. I always use a bit of anti seize compound on the new plugs too. Saves them getting stuck in the future.
  4. scoobydoo1098
    Nov 10, 2013
    Thanks Rodders. This is exactly what was done to free it. I asked why they don't check them before 65000 and Audi said it was due to them taking 3 hours to remove and also they shouldn't need it as they are platinum
  5. stevegarrard
    stevegarrard New Member
    Jul 10, 2014
    hi scoobydoo,
    I`m about to buy an 09 rs6 any other issues you have found with yours?
  6. stevegarrard
    Jul 10, 2014
    V10 ISSUES ARE THERE ALOT?
  7. scoobydoo1098
    Nov 10, 2013
    The spark plug issue was the only one I had in two years of ownership apart from the obvious fuel costs.
    Fantastic car. Was sad to see it go
  8. stevegarrard
    Jul 10, 2014
    thanks Scooby!!!
