spark plug help
gussyldr Dec 8, 2010
  1. gussyldr
    gussyldr Member TFSI Owners Group quattro Audi A3 S-line owners group s tronic Team Brilliant Black
    207
    hi all couple of questions
    (1)does any one know if eurocarparts, gfs or halfords sell ngk bkur7et?
    (2)also can some one tell me what size coupling ill need to fit my air filter to the mass air flow meter?
    (3)and what have pepole done with there ignition amp after fiting a induction kit or air filter?
    thanks
  2. bengal
    bengal Member
    537
    1. Im not sure so it would be best giving them a ring.
    2. I think its 70mm although i could be wrong.
    3. It needs to be attached to a metal surface a lot of people have made a bracket up for it and it also needs thermal paste between the contact surfaces. The reason its on the airbox is so it is kept cool so keep that in mind.
  3. DaveA3
    DaveA3 Audi A-Trizzle!
    2,370
    15
    70mm is A3 80mm is S3 for the coupling. not sure about the plugs.
    regarding the ignition amp u dont really want it on the metal causing vibrations and wearing away the surface taking away the thermal protection on the heatsink part. Just cable tie it to ur induction pipe and itll be ok. if u have a cold air feed point the ignition amp in that direction.
    Although if not it will be fine with a good even layer of thermal paste between the heatsink and ignition amp
  4. gussyldr
    207
    thanks for the replies
