Spark plug experts please
Jp-tqs Feb 3, 2013
  1. Jp-tqs
    Jp-tqs Member
    183
    Changed my spark plugs on my 1.8t bex today, all went well. My question is.... from the pic is this a healthy spark plug i removed? And also how much oil is acceptable where the SP sits? Ie, looking down in to the apperture before removing the plug there was a small collection of oil. Not loads just a few drops sat on a machined shoulder.
    Bosch super 4's went back in, done my air filter too. Car got some love today!
  2. Jp-tqs
    Jp-tqs Member
    183
    Forgot to add pic! ^^^
  3. T0m
    T0m Active Member
    516
    26
    mate sounds like your rocker cover gasket is on its way out, thats what happened to mine didnt take the plugs out though and when i swapped mine out the other week they were dry no signs of oil penetrating into the plugs and I changed my gasket last summer.
  4. demus
    demus Fire in the hole..
    355
    19
    I would say from that plug the engine is fairly healthy.. its hard to read a plug nowadays cos there is nothing decent left in the fuel..
    Tip colouring is gentle throttle, colour deep in the plug is full throttle, timing can be read from the earth electrode, plugs can tell you everything..
  5. stu_m
    stu_m Well-Known Member VCDS Map User
    1,441
    as above thats a nice healty running motor
    and change your rocker cover gasket and all will be well with the oil the last thing you want is for the oil to earth the plug cap and cause the car to stop
  6. Jp-tqs
    Jp-tqs Member
    183
    Thanks for the replies, it runs sweet except for the first few seconds of start up on cold mornings. Engine shakes on its mounts like its gonna fall out for about a second then all is fine. Its hard to describe though.
  7. stu_m
    1,441
    thats just because its a cold **** :D
  8. pauldazzle
    pauldazzle Well-Known Member
    1,189
    93
    Plugs look good.
    Re poor cold start. Check to see if you have the old black coolant temp sensor if you have replace it with a genuine revised green Vag CTS.
  9. DWH
    DWH Member
    50
    I've got the same Bosch FR7KPP33+ plugs on my 2003 standard 1.8T . What gap should they be ?
    I've also got the same issue with oil so I'll be replacing the rocker cover gasket in the very near future.
    David
  10. Ian2012
    Ian2012 Active Member
    473
    29
    Our BEX engined car runs much better with a new CTS i can't believe it
  11. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,819
    197
    im no expert but imo the plug looks too clean on the insulator. should be lightly tanned . So i looked it up and my answer would be a shameless copy from another source.
    A clean white insulator firing tip and/or excessive electrode erosion. This is often caused by advanced ignition, timing, poor engine cooling efficiency, lean air/fuel mixture, or leaky intake.
    Check the plugs correct, fit some good quality ones and check correct gaps, makes all the difference in turbo cars, more boost = smaller gap too.
  12. DWH
    DWH Member
    50
    Is the CTS also an issue on B6 cars ? Are there different versions of the green one ?
  13. Mike_B
    Mike_B Active Member
    533
    47
    x2 - part number / location advice too please - -
    Thanks, Mike.
  14. DWH
    DWH Member
    50
    I found this article, written in the states.
    AudiWorld Tech Articles
    Can anyone in the UK confirm that the green one can / should be used to replace a "normal" 2003 B6 version
    Are the electrical connectors the same ?
    David
  15. pauldazzle
    1,189
    93
    Connectors are the same. Use a genuine VAG green CTS only or you'll be buying twice.
