Spare Key Cost?
pazaz Feb 5, 2011
  1. pazaz
    pazaz Member
    323
    How much would it cost to buy a spare key?
    It only has to be a key to allow me to get in and start the car should I ever loose the only one I have.
  2. Lings
    Lings Active Member
    2,059
    31
    Just bought one off ebay for £10.50 need to reblade it but thats cheaper than buying from the stealers ..
  3. Cabbyfan
    Cabbyfan Active Member
    840
    34
    If you have an immoboliser you will need to have it programmed to..... about £50 at a dealer....for an A4 anyways, A3 may be different. A new key is abut £130 from a dealer for an A4.
  4. Lings
    Lings Active Member
    2,059
    31
    Cant you use vag comm?
  5. mike foster
    3,967
    No !
    The 8P has a code in the immobiliser which only Audi Germany can read. Well that's almost true as there is a piece of kit only sold to verified specialists that can read the 'hidden' byte but as yet they have not developed it as far as the 2006MY.
    The key from Audi is about £160 which includes getting the code from Germany and then the dealer matching the lock/unlock code which is done using VCDS or similar. The alarm and unlock/lock is totally separate from the immobiliser.
    Also the blade length has changed and the new size is difficult to obtain and Audi will not sell them.
    The one you have bought off ebay is only any good for opening the doors (after re-programming assuming the frequency is the same) and disengaging the steering lock. It will not start the car.
  6. tdi-man
    tdi-man Well-Known Member
    1,783
    64
    i bought key of ebay on same frequency then u need to get the pin code out of your dash and get a new chip programmed and coded to car ...
    mine works fine and starts car all in all cost me half the cost of a dealer key
  7. mike foster
    3,967
    You don't say how you got the pin code !! Did you do it, or did someone with the kit I described do it for you ?
    And what year is your car because it appears pre 2004 i.e 8P1 did not have a problem ?
  8. tdi-man
    1,783
    64
    you need to get a lock smith to pull the pin code and coding of your car...mines a 54 plate 05 build.
  9. tdi-man
    1,783
    64
  10. Lings
    Lings Active Member
    2,059
    31
    The local locksmith disagrees
  11. tdi-man
    1,783
    64
    yes i disagree as well my lock smith cut a key for me which works fine.
    my key fob opens locks and starts car no probelms.
    Its programing the chip is the probelm not many people can do
  12. mike foster
    3,967
    Interesting guys. My chap has tried with his latest update software and couldn't do it.
    Whilst I was there he rang the software support team and told them the problem and they said they had not completed development for that year of car (2006 MY).
    He has all the blank modules and the kit to write them but can't yet get the 'hidden' bit.
    Programming the unlock/alarm is no problem.
    Presumably you have the new shaped key with the metal strip down the side ?
  13. tdi-man
    1,783
    64
    i have the 3 button key.
    my lock smith has only just been able to get the pin code and byte informaton.
    i watched him do it not that easy...
  14. mike foster
    3,967
    Yes 3 button but does it have a metal strip running down the opposite side to the keyblade and underneath ?
    Reason I ask is because the 3 button key before this latest one with the metal strip down is easier to code.
    Apparently the security was enhanced with the latest key. Also the length of blade on the latest one is shorter than the previous 3 button key. Not sure what difference that makes but apparently the blanks are hard to come by.
    My key part number is :- 8P0 837 220 and the blade code is HAA
    picture added to avoid any confusion
  15. tdi-man
    1,783
    64
    no metal strip runing down the oppisite side.
    blade is HAA.
  16. mike foster
    3,967
    That's the difference then mate - you have the earlier key that can be copied.
    At the moment mine can't which was the basis of my comment in the first place ! lol
    Thanks for your input - helps other people to understand the difference in key coding (and copying ) between 8P1 and 8P2
  17. pazaz
    pazaz Member
    323
    So am I correct in saying my 2007 spare key (to access and start car) can only come from the dealers at approx £130?
  18. mike foster
    3,967
    Yes, almost certainly, but it will be nearer £170 now !
  19. pazaz
    pazaz Member
    323
    £170 for a spare key that I may never use seems a lot!!
    If thers no other way to get a basic spare to open and start the car I may take the risk and not bother just yet.
  20. mike foster
    3,967
    I know mate - I haven't got one either for that very reason !
    I'll let you know if I find a way !
  21. pazaz
    pazaz Member
    323
    Surely there is a cheaper way just to have a spare to open and start car? even if its not the flash 3 buttom flip key
  22. mike foster
    3,967
    The opening bit is the easy bit it's starting the car that you can't do.
    Presumably Audi have made stealing the A3 very difficult because it's a very desirable motor! That is why getting the bit of information out of the immobiliser that is coded in by Audi at manufacture is almost (but not totally ) impossible. Audi have certain procedures to follow before they will release the coding and that, combined with the remote locking synchronisation and the cost of the key fob itself and cutting the blade comes to in excess of £150.
    This only applies to the key fob shape as indicated in post #14. The previous 3 button keyfob can be reproduced much more easily.
  23. pazaz
    pazaz Member
    323
    Cardiff Audi quote today~
    £129.00 for the key
    £88.00 to programme
    £45.00 for the plastic key that only opens the doors!
    Thats unbelievable.
  24. mike foster
    3,967
    So, presumably, you now believe me do you ??? :think:
  25. Lings
    Lings Active Member
    2,059
    31
    Daylight robbery
  26. pazaz
    pazaz Member
    323
    Fossie, Prices seem to vary so much I thought I would get a local dealer quote. Didnt realise you confirmed it was £217.00for key and programming.
    They should start wearing masks in the dealers (robbing B******S)
  27. mike foster
    3,967
    I didn't confirm it was £217 - I said it was in excess of £160 which everyone seemed to think was nonsense !!!
    You can get a key to lock and unlock the car for less than £20 but it won't start it !!
    And you can't just blame the dealers - it's the cost that Audi Germany charge to release the information coded at manufacture.
    You should be pleased that they are protecting our investment by making it impossible to steal without a key and making the key so expensive that only idiots would try and buy one !!!lol
  28. pazaz
    pazaz Member
    323
    Fossie, I agree, but im sure the local Audi dealers have a cushtie mark up.
  29. 1animal1
    9,978
    Was speaking to someone last night who knows a private individual,ex vw....who apparently can do everything the dealer can, chap says he has a security key fob to allow him full access to the official dealer vag site. I'll ring him on monday to see what he can do
  30. mike foster
    3,967
    Nice one animal - don't forget to tell him that the problem is with the new shape 3 button key on the 8P2 onwards. Mine's a 2006 MY but the new shaped key may have started in 2005.
    I see yours is a 2009 MY so you could ask him to try and clone that ?!!
  31. 1animal1
    9,978
    Will do mate, I had been following the thread and mentioned to my mate who's a mechanic - apparently this chap will do a lot more than the local dealers know how to do, proofs in the pudding so fingers crossed but good news that he's got direct access to the VAG main frame (if that's right)
    I need a spare too as mine only came with one - worried as losing the key will cost me more than £200 ;)
  32. Gti Jazz Blue
    Gti Jazz Blue Active Member VCDS Map User
    1,655
    But as the legal owner of the vehicle, there should be a route for you to get the security code for your car. After all the cluster containing said security code, no longer belongs to Audi, it belongs to you the owner.
    I can understand the need to keep the code secret, but for those of us that would like that information, there should be some way of getting it. I'm suprised that the EU doesn't view this as a restrictive practice.
    Paul
  33. 1animal1
    9,978
    Jazz, some things like this are best kept as Audi have done, i for one am not disturbed by this...... next phase is selling on the programming to be able to rekey which means the chances of my car having a key cloned/made dramatically increase!!
  34. mike foster
    3,967
    I agree.
    Have you had a chance to speak to your mate yet animal ? I too only had one key when I bought the vehicle. I do have another that locks and unlocks but will not start. It will however take the steering lock off if ever I need it towing without the original !!
  35. Gti Jazz Blue
    1,655
    Yet you are comfortable with your mate having access to the VAG MainFrame ?
    I guess we might disagree on this one, but I think that I should be able to make the choice about having the code for my car.
    Paul
  36. 1animal1
    9,978
    Paul you suggest that you as an owner should have access to your code,i have a mate who knows an ex vag tech who subscribes annually at a cost of approx 6k to the vag mainframe, explain who is most at risk bearing in mind that yours would be much more readily available, then read your comments back and have a word with yourself
    Mike, not yet mate, you've just reminded me :)
  37. Gti Jazz Blue
    1,655
    No word with myself at all required :laugh:
    Just because the guy spends 6K on a subscription, doesn't necessarily mean that he is an honest person (no offence to your mate).
    All I'm saying is that should I decide that I want to have the code for my car - there should be a way to get it out of Audi. I'm not likely to leave it on a bit of paper in the car or lying about (mind frankly if I decide that is what I wanted to do - it should be my right to be able to do so).
    I have VCDS so with that info I could order a new key from Audi and not have to pay the stealer to code a key using what is my security code from my instrument cluster (not Audi's) :thumbsup:.
    Paul
  38. Cardiff R33
    Cardiff R33 Member
    39
    Any news on this? In summary, whats the cheapest way to get a full working key for a 53 plate car (no silver strip)
  39. mike foster
    3,967
    Buy one off ebay with the correct frequency and get it recoded and rebladed at a VAG /autolocksmiths.
    The earlier three button key like yours is easy to reproduce - it's the one with the strip down the side that we are talking about that is difficult to copy.
