Spacers...
mattdsc Jan 23, 2010
  1. mattdsc
    mattdsc Member
    72
    I have no when it comes to spacers, so a little help would be appreciated!:faint:
    What would I need if I was to buy spacers?? How many of these would I need to do the whole car?
    http://cgi.ebay.co.uk/10mm-Alloy-Hu...arts_Vehicles_CarParts_SM?hash=item3efc27b544
    Do I need one set of these for each corner or do I use one spacer per corner. Do they look any good? Any recommendations on what I should get? I have read on posts that 20mm spacers may be a little much and casue rubbing. My plan is to use H&R shocks on standard dampers and then increase the stance of the car with spacers. I dont want to run into any rubbing on arches, just a little cosmetic change.
    Please dont laugh, just a total newbie to all this!
    Matt
  2. RobinA3
    RobinA3 Well-Known Member
    1,827
    47
  3. mattdsc
    mattdsc Member
    72
    Thanks for the reply. So are you saying 12mm only on the rear? Non of the ones on the link you posted are 12mm? Help?!
  4. JustCharlie
    JustCharlie Member
    295
    10mm at the front, 12mm at the rear, you will get a bit of rubage at the rear but its only on a liner screw that you can remove and trim or fit a smaller headed screw Buy decent quality hubcentric spacers, Damian at DPM will sort you out with some H&R ones that are top notch
  5. N8
    17,163
    718
    You want H&R spacers, don't scrimp on quality, 10mm front, 12mm rear..
  6. RobinA3
    1,827
    47
  7. N8
    17,163
    718
    Damian offers great service at DPM, so I'd get them from him!
  8. SimonAshley
    SimonAshley Member
    87
    Bit expensive for some pieces of metal. Isnt there anywere that sells them cheaper?
    Or can Damian at DPM do a good price?
  9. N8
    17,163
    718
    They are expensive but you pay for what you get Simon, those are the best ones you can buy!
  10. mattdsc
    mattdsc Member
    72
    Thanks Robin, much appreciated.
    Why is it recommended to do wider at the rear?
  11. N8
    17,163
    718
    Rears sit in more, so you want staggered stance...
  12. mattdsc
    mattdsc Member
    72
  13. mattdsc
    mattdsc Member
    72
    You say there is a liner screw that can cause scrubbing on the back....where abouts is that? Top or sides?
  14. PaulAr
    PaulAr S3 (8P)
    4,073
    186
    Get your springs now from Awesome while they have them discounted.
    £180ish will get you a set of H&Rs delivered.
    Bargain.
    cheers
    Paul
  15. V6Pete
    V6Pete Now running on Bentley's y'all
    1,491
    Spacers are just CNC's lumps of metal, so often the unbranded spacers can be as good as H&R. I know a company that manufactures spacers for many large German tuners, but if they sold them unbranded, people wouldn't touch them.
    The problem is sometimes the unbranded spacers can also be ****. When it's something effectively holding your wheel onto the car, you don't want to mess about. The fit needs to be 100% perfect, and the raw materials very good quality.
  16. mattdsc
    mattdsc Member
    72
    Thanks Pete
  17. N8
    17,163
    718
    Nice one Pete :respekt:
  18. polo classic
    polo classic New Member
  19. V6Pete
    1,491
  20. RobinA3
    1,827
    47
    Remember that the H&R's come with the longer bolts, some of the cheaper stuff doesn't include the bolts which can cost £40 and can also be a right pain up the **** to get hold of.
    end of the day you get what you pay for.
  21. RicoS3
    RicoS3 Sprint Blue is the new Ibis!
    621
    68
    Quick question on spacers, I have been talking to a friend on this (thanks Carl) and he states that the front track should always be wider than rear on what is essentially a front wheel drive car, gives better turn in and scrub radius.
    So the S3 stock has a wider track at the front, so for example, would adding 6mm spacers on the front (12mm in total) and 8mm or 10mm on the rear (16mm or 20mm in total) still maintain the wider track up front, but give the car the desired look I'm looking for, rear wheels filling the arches better? I should mention that I'll have the car lowered on H&R 25mm by the time I look to have spacers on.
  22. Japper
    Japper Ibis S3 Fan Club
    1,495
    According to Audifans the front track is 1522mm and rear track width is 1506mm.
  23. RicoS3
    621
    68
    Cheers Carl, for this and the other info. I want it to look better (IMO) stance-wise, but not effect the handling too much. Take the point that I'll not be driving it like on a track from day-to day, but want to ensure the front track remains wider than the rear.
