spacers with standard wheel bolts?
crazypainter Jul 8, 2011
  1. crazypainter
    crazypainter Member
    594
    Up to what size of wheel spacer can I run with the standard length wheel bolts?
  2. hades-
    9,481
    646
    well iv got 8mm on the back and needed new bolts
  3. mattyboyc
    mattyboyc B6 Veteran Audi A4 Audi Avant Owner Group TDi
    1,989
    214
    I used to run 5mm on the front and that used longer bolts,so i would say none, for peace of mind i would always use longer bolts, what size you thinking of running?
  4. crazypainter
    crazypainter Member
    594
    I havent measured yet, it would only be on the rears anyway. Sounds like any spacers, require longer bolts, as you say, peace of mind !!!
  5. ASHIHARA
    ASHIHARA Member
    294
    15
    I have 6mm wheel spacers and yes,i have longer bolts.
  6. holmefield
    holmefield Member
    448
    20
    To be safe you need @ least 6 full turns @ the front and 5 min @ the rear. 5mm spacers should be fine above that longer wheel bolts for sure..
    crazypainter likes this.
