Spacer advice for my new wheels please :)
DJ_Troopa Apr 20, 2010
  1. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    Afternoon! A few bits of advice needed please!
    My wheels are 8x18 ET35 and going to be lowered on coilovers.
    I see people go for 15mm rear and 10mm front. Can i push it and go for 20mm on the rear? I wanna have the car sitting on the tyres nicely but i don't want scrubbing issues if i do spacers.
    Then i was told i can't do 10mm on the front as i'll get vibrations or something like that and also get hubcentric ones?
    What's a man to do!? Help!
    Thanks all!
    Jay
  2. s3_stig
    s3_stig Member
    376
    I have 15 front 20 rear and have no problems
  3. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    How low are you matey and what is the spec of your wheels? What spacers do you have? Also are they hubcentric?
    Cheers!
  4. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,267
    360
    whats the width of the rim and the ET, stig?
  5. Maz
    Maz Moon is made of green cheese
    1,002
    10
    I have the same size wheels as you Troppa and have the 10F/15R hubcentric H&R Spacers. They cost a packet compared to regular spacers but I didnt want to scrimp and then get issues... There is space to go wider but I stuck with the tried and tested option.
    I know there are a few guys running 15F/20R but never heard any of them complain.
  6. JD09
    JD09 I'm not modding, I'm improving VCDS Map User
    3,096
    46
    What did you end up paying Maz and where from? Saves me hunting around for the best price.
  7. Maz
    1,002
    10
    I got mine from http://www.motorsportworld.co.uk/ about a year and half ago when they were the cheapest. I also got a discounted price because my shocks/springs and exhaust were all from them.
    I can't remember exactly how much but just over £100.
  8. s3_kev
    s3_kev Stage2'd!!!!!!
    2,002
    23
    i have 10f and 25r with same wheel setup as you currently with coilovers wound right down, but at this setup you need to no what camber settings you want and also depends if you can get your car as low as mine if you went for this setup. to be safe though id go with 20mm rear. i recently put my 25m on to the front and think it would be ok but doubt it drive very well with such little et, so again to be safe max on front would be 20mm with 20mm front and rear the tyres would sit nicely in the arches if you want rears to apper to sit out a little more then the fronts go 15mm up front
  9. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    Thanks for that Kev :icon_thumright: I think i'm gonna do 20mm rear and 15mm front. Where did you get your spacers and what's the deal with 'you HAVE TO get hubcentric spacers'?
    Jay
  10. Andrew@A.L.D
    3,879
    617
    when you say you have 15mm front and 20mm rear is the rear spaced out 20mm per corner or 20mm in total rear and 15mm in total front?
  11. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    It's 20mm per corner rear and 15mm per corner front.
  12. Andrew@A.L.D
    3,879
    617
    Sorted thank you its just place advertise it as in total
  13. s3_kev
    2,002
    23
    hubcentric is so the spacer sits onto the vehicle hub to centre the spacer so its not all reliant on the wheel bolts being done up square. also you then get the hub part on the other side of the spacer so the wheel sit onto the hub as it would normally again to make the wheel centre'd. if you dont use hubcentric then there is a chance the wheel wont be centred so will cause judder/vibration as if the wheel is massivly unbalanced.
    you probbaly cant get non hubcentric at these sizes anyway :icon_thumright:
    brought mine from dpm
  14. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    I can get non hubcentric ones in these sizes no problem. So does that mean all those people who have non hubcentric spacers suffer from judders and vibrations? My friend has non hubs on hubcentrics on his car and he's doing fine. Its alot of money for spacers lol just don't want to spend tooooo much!
    Thanks!
  15. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    Kev - what make of spacers are you running mate?
  16. sulaiman
    sulaiman Member
    274
    speak to mk1tony on ab25, he'll make you some! :) (hes got the fabia on air ride btw)
  17. Y83OLK
    Y83OLK Hulk Smash!
    841
  18. vanilla_ice
    vanilla_ice Active Member
    707
    Do you know if when you mix and match, will all the spacers be anodised black?
  19. 123holah
    123holah Member
    55
    What are spacers like for stone chips as i want some on mine but dont wanna ruin my perfect paint! i think mudflaps might be an option for me but then i dont want them to catch when i lower it!?!
  20. s3_kev
    2,002
    23
    you are running the risk of stone chips depending how far out you push the wheels,
  21. hillg81
    hillg81 Member
    94
    http://www.dpmperformance.co.uk/wheel-spacers-vag-5100-571-c-2207_2868.html
    £200 for a full set or more or less??
    Sound right???
  22. DPM
    DPM Site Sponsor Site Sponsor
    5,023
    206
    Hi Gaz,
    Give us a shout if you'd like any more info or any prices.
    Damian @ DPM Performance
