Sounds expensive.... lol.
Welly Jan 4, 2012
  1. badger5
    9,421
    1,965
    in race trim its turned down to tractable(ish) level
    on full chat it will spin up every gear in the dry, so not much point.. We have to use list 1a tyres for combe saloons, which is regular tyres.. not even track day rubber, so that limits power effectively. Its nice to know I have it is about all I can say - lol
  2. Welly
    Welly VX220 SC Driver :)
    10,696
    127
    OK, so to re-rail - the Haldex is not working at all again this morning, making the yellow thing like a nuclear bomb with no guidance system.
    I was hoping really that this problem would just go away, but sadly that appears to not be the case. Booo.
    Will go out and scan it in a bit.
  3. Gops
    3,198
    666
    Ahh man I remember when mine was fwd and that was mad.. Yours must be crazy! Hope you get it sorted mate! Good luck!
  4. colicabcadam
    colicabcadam Guest
    what did you change? the whole unit? is the pump built into the unit? or is it external?
  5. Gops
    3,198
    666
    Is that question for me? If so I changed the controller, from what I know the pump is separate I think.
  6. colicabcadam
    colicabcadam Guest
    LOL - for OP lol
  7. BENJAMIN
    BENJAMIN Active Member
    503
    93
    Activate the haldex oil pump in output tests and get underneath to check the pump is buzzing away. When I replaced my diff, I fitted the new one to find it didn't work for 2 reasons.
    1- my replacement diff was off a 03 R32 with esp and mines a 99 apy with no esp. The late ESP controller did not work with my non ESP car. Weirdly the r32 haldex ecu wouldn't even communicate with my abs (can bus difference possibly?)
    2- the replacement diffs oil pump wasn't working properly and made the car run in 2wd all the time.
  8. Welly
    10,696
    127
    Not changed anything yet, trying to avoid changing anything...
  9. Welly
    10,696
    127
    I ran the output test earlier and I could hear the haldex doing it's thing. Have been driving it about today as well and have had no AWD issues. Intermittent at best, and the front only seems to spin in the wet.
    I wonder if the haldex is still working, but the front tyres just can't grip in the wet. Not sure. Weird. Having said that, had noises from the back recently which have stopped now, and a haldex fault code... It's got to be on it's way out to be fair.
  10. sportstractor
    sportstractor Chugger
    2,709
    I hate to say it, but trying a simple oil change may do the job? Iv read loads of times that this fixes alot of problems
  11. Welly
    10,696
    127
    Did consider that - only had one done inside the last 5K ish though. If problems continue I might before changing the whole diff.
