Sound after gear change.
Icey Jan 20, 2014
  1. Icey
    Icey Member
    121
    13
    So I have a 2.0 Tdi and I have these questions.
    First gear feels powerless?
    Maybe it's only me getting friendly with the clutch.
    After second gear when I press clutch and change I hear a woosh sound almost like a dump valve?
    <like 2 gear just when change woosh 3 press clutch release acceleration woosh>
    ( want to be sure it's not a problem )
    Is there any way to reduce the engine noise ?
    All these questions might sound stupid but I have never owned a diesel as I had a petrol 1.2............
  2. Icey
    Icey Member
    121
    13
    anyone ?
  3. sliced
    sliced Drive safe, stay alive.
    1,524
    327
    Is this your first turbo car?
  4. Icey
    Icey Member
    121
    13
    yes.
    and im paranoid :D about every noise :D
  5. sliced
    1,524
    327
    fair play, the woosh sound is perfectly normal
  6. Sidhu88
    Sidhu88 Active Member
    808
    76
    If its silly loud it might be a faulty diverter valve, might be worth getting it checked out. I've been in a few 140hp models and some have sounded different to others. The noise is more noticeable with non standard air filters
  7. Icey
    Icey Member
    121
    13
    I do live the woosh sound , hehe but i was worried ;) thanks. I'm getting used to diesels :)
  8. Icey
    Icey Member
    121
    13
    What sort of rpm your 2.0 Tdi idles at? Mine is between 900 and 1000
  9. Sidhu88
    808
    76
    Bout 800, higher on a cold start, higher still if the heaters or demister is on high heat. It'll pick up revs to 1k by itself
  10. SootySport
    SootySport Well-Known Member Team Silver
    2,585
    664
    Maybe the previous owner fitted an aftermarket dump valve? You shouldn't get a Woosh sound between gears.
  11. dannyh1991uk
    dannyh1991uk Member
    179
    TDI's don't have Dump Valves.
  12. Icey
    Icey Member
    121
    13
    Soot1 the whoosh sound is right after acceleration. Like boost kicks in and if I easy off the acceleration then get the woosh.
  13. SootySport
    2,585
    664
    Never done that on any of my VAG tdi's, and I've had a few.
  14. SootySport
    2,585
    664
    Exactly.
  15. Icey
    Icey Member
    121
    13
    Sound is still there. Plenty of power but when I release acceleration comes the woosh sound........ To be fair I was listening a lot to it lately and it sounds like it comes from the exhaust ( like between dahs board and rear seats , more like a pressure in the exhaust )
    Booked in at AUTOAPS for a health and boost check ;) let's hope the best :)
  16. dannyh1991uk
    dannyh1991uk Member
    179
    How much does a health check cost? Lol
    Just wondering cuz obviously just buying a used car i want it to be perfect before the warranty runs out lol
    Icey, did you manage to sort the problems with your door mate?
  17. Icey
    Icey Member
    121
    13
    They said its £50 :) for the health check. No the door is the same :( didn't have any time to her to it.
  18. DriverN00B
    DriverN00B Active Member
    352
    34
    How loud is the whoosh? Audible with your windows up?
    Sure it isn't just the turbo whistle?
  19. Icey
    Icey Member
    121
    13
    yes you can definitely hear it with the windows up.
    Don't know if its from the turbo.
    what happens is i'l pull away with first gear, and then second gear boost comes in and when i take my foot off acceleration and sound like woosh like relasing preassure in the exhaust or somewhere ( its sound like high pressure leak of some sort not sure.)
  20. emznjav
    emznjav Member
    76
    Mines the same but its only apparent between 2nd and 3rd. Sounds like a pigeon cooing. I quite like it tbh.
  21. JRock247
    JRock247 Active Member VCDS Map User
    509
    45
    I have the same noise in my TDi 140 BKD, even with a brand new turbo fitted, so must be normal. Never been told any different by my mechanic/audi.
    I like it :)
  22. chrismoore
    chrismoore New Member
    21
    mines does the same when the windows are down.
  23. Icey
    Icey Member
    121
    13
    like mine :D
    i'm feeling good now :D i was worried
  24. dannyh1991uk
    dannyh1991uk Member
    179
    I think i know what your on about... At first i thought it was the Thrust Bearing but surely that would be mosty noticeable in 1st-2nd
  25. temoore1993
    temoore1993 New Member
    12
    I also have this noise, was expecting it to go as i had new boost pipes fitted today however still there. Car still pulls very well, even though i do have a high pitch noise from the turbo which i asked my garage if i should replace it or how long it will last. The reply was that i shouldn't worry too much and for the turbo lasting he replied with 'how long is a piece of string'. So overall until something gives way all is good!
