Sorry sorry sorry... bulb question
aythree Apr 14, 2009
  1. aythree
    aythree Guest
    Been reading past posts on this and other forums re: bulb upgrade.
    At the moment i've got the standard "yellow'd" bulbs, but would like to get that bright white/blue look to my headlights/fog lights.
    Don't want to go down the HID conversion route (or whatever it's called).
    Would just like to purchase some new bulbs but would like to know if anyone can recommend any.
    Seen Phillips Extreme and Osram Nightbreakers mentioned. Any good??
    Actual product number or spec of recommendations would also be helpful if poss. Won't be seeing my car again till later this week, so won't be able to check which type of bulb I need, and would like to buy some before then.
    Thanks guys.
  2. ollyhawkeye
    ollyhawkeye Member
    101
    I have xenons so didn't need to do mine, I did however do the indicators and DRLs. I had nightbreakers in my previous car and upgraded the Mrs' car with them too. Never had any problems so can reccomend those.
    If you search the FAQs there is a good thread in there on all the different types and where they go etc.
    Powerbulbs have a nice and easy site to navigate although other retailers are available.
    Olly
  3. ollyhawkeye
    ollyhawkeye Member
    101
  4. aythree
    aythree Guest
    Very helpful.
    Thanks.
  5. aythree
    aythree Guest
    Ok, I've read the entire 160+ posts in that thread and now my head is slightly spinning :uhm:
    My car is a A3 2004, no DLRs. Just standard headlights with fogs in the bumper - it's a Sport.
    Basically I decided I want to go for the bulbs which leave a blue tint when off (my car is silver and I reckon it might look ok), so it's between the phillips x-treme power or the PIAA xtreme white plus.
    From what I understand these are the following bulbs I need.
    Side lights.... W5W / H222
    Dipped beams.... H7
    Main beams...... H1
    The main beam bulb is confusing me a bit though. On some websites that sell bulbs they say I need H7 from my main beams, which is the same as the dipped beams. Elsewhere I have read I need H1 from my main beams?!?!?!
    Which is correct??
    Are there differences across the A3 models??
    Also, got fogs in the bumper that i'd like to do.
    Main beam bulb again..... H1????
    :keule:
  6. redbutcher
    redbutcher Member
    649
    I'd try to go for bulbs with less of a blue tint when off as trust me it will annoy you.
    Bit of a lengthy thread that isn't it :laugh:.
    I think that a fellow member went for the dip beam PIAA upgrade and had to get H1s, but that was for a later year than yours. It might be worth if someone with ETKA reading this thread could check the part number for us please for a 2004 main beam bulb (or I suppose you could check with your dealer or see if the manual has any info).
    If you do go down the PIAA route, the bulbs are not cheap though for the main beam, so if you're looking for a credit crunch compromise, try the Philips bulbs.
    Personally I wouldn't bother with the fog lights - don't see the point for the amount they get used.
    Can definitely recommend the PIAA bulbs for the sides though - very nice white light they produce.
  7. Lee_R
    Lee_R Active Member
    2,499
    12
    The dipped and mains are both H7 and so are the fog lights, I've made this mistake myself! Do not buy H1, maybe H1 is for the Xenons?
  8. aythree
    aythree Guest
    Thanks.
    Think I'll go for the blue tint ones though.... always kinda liked them, I think! :think:
    Had a look at the prices of the PIAA and yes, the are expensive... for bulbs!! :wtf:
    Just ordered the H7 Philips X-treme Power bulbs, from powerbulbs.com, plus free bluevision side lights, delivered for £22.50 (used a discount code). :yes:
  9. A2A6
    A2A6 Member
    34
    Hi,
    I went for OSRAM Nightbreaker H7's. Very white appearance, bright white balanced beam throw. Same bulb for dipped and main beam. Also got some "blue" (but very white light) 505 side lights so front is now
    "all white"! :thumbsup:
    Paul
  10. MikeSel^
    MikeSel^ Moderator Staff Member Moderator Team Navarra TFSI Owners Group Audi S3 quattro Manual
    1,058
    471
    Any chance you can post some pics up of them on it the dark? I am also looking for the same results on my 05 sportback.
  11. Staz
    Staz is a retronaut Staff Member Moderator VCDS Map User
    6,206
    64
    H1s are you main beams aren't they? I had halogens on my old A3 there was one lens that contained the side and dipped bulbs and then one that only contained the main beam.
    This is an H1 and it's the same as the main bulb IIRC:
  12. Cali
    Cali Member
    135
  13. aythree
    aythree Guest
    I think H1s are the main beam on the more recent A3s (not sure from what year).
    But on a 2004 the dipped, main beams and fogs all use H7s.
  14. Staz
    6,206
    64
    Dipped and mains perhaps but not fogs!
    I assume it has 2 of these, one in each lens yeah? I may have been wrong, I sold the car 18 months ago.
  15. aythree
    aythree Guest
    According to powerbulbs.com and other sites I have checked fogs are also H7.
    What bulbs do u reckon they should be??
  16. frenchy2475
    frenchy2475 Tetbury Audi Parts Man
    263
    Depends, if its s-line it has a H11 if its not it has H7.
  17. aythree
    aythree Guest
    I've got a Sport.
    Complicated, buying bulbs!! :keule::banghead:
  18. Staz
    6,206
    64
    Something isn't right here! So you're saying that the fogs use the same brilliance bulbs as the dipped and main beams?! That's very bright fog lights
    EDIT: Just had a look on Halfords and they say the same thing. I still can't believe it though!
  19. aythree
    aythree Guest
    Aren't fogs supposed to be bright? Brighter the better I wouldve thought. So they can shine through the fog?
  20. Staz
    6,206
    64
    Yeah but they point to the floor. When I turn my fogs on they light about 2 metres in front of the car, so any light going forward is not the main brightness. That seems a bit of a waste to have powerful H7s only to shine them down.
    Compare it to your dipped beam mate. Turn on the fogs with sides, then turn them off and turn on dipped. There's no comparison!
  21. aythree
    aythree Guest
    I didn't even realise that fogs pointed down. Thought they just went straight forward, or maybe only very slightly down.
    I'll give what u said a go though.
    I've only bought dipped and sides at the moment. Not gonna buy any mains (how often do i really use them!).
    The boys in blue :busted_cop: are a bit fussy round here, and like to pull you for driving with fogs on, so i'm still undecided on getting upgraded bulbs for my fogs for now.
  22. jb0o
    jb0o North East Forum Moderator Regional Rep Site Sponsor VCDS Map User
    2,663
    116
    Bought some Philips Xtreme Power in White. They're amazing!
  23. phil76
    phil76 Active Member
    572
    40
    Fog lamps also have different lenses though which are thicker glass same kind of idea as the old calibra and TT lamps where the glow is magnified,your normal driving beam is the same bulb as the fog lamps as mentioned from what i remember and only did mine last week with the night breakers
  24. 330_2_S3
    330_2_S3 Member
    242
    S3 FOGLIGHTS (ONES ON BUMPER) ARE H11 NOT H7
