sorry! ISO harness question!
stapo69 Mar 29, 2007
  1. stapo69
    stapo69 All hail the mighty quattro!
    969
    Right, I've looked and looked through this forum and I've ended up getting more confused about which lead i need for my car to connect my kenwood head unit
    I have a 1999 S4, full amped Bose. Which ISO connector do I need? The one to connect my head unit RCA's to the existing BOSE set up?
    Please help, once and for all! Even ICE specailists have given me different answers!
    PC9-401? PC9-404? PC9-408? PC9-410? AAAAHhhhhhhhh
  2. Randomjim
    Randomjim Active Member
    2,752
    PC9-408 i believe
  3. AndyMac
    9,832
    45
    the 408 will connect to your speaker outputs and use a hi-lo converter to take the amped signal back down to RCA/pre-out level, which then gets re-amplified by the Bose amp.
    The 410 is just a straight adapter that takes the front & rear RCA's directly into the Audi loom to feed the Bose amp.
    You can use either, but the 408 will compromise the sound quality as it's being amplified twice, so more distortion and background noise.
    The 410 is theoretically the best one, but can produce really annoying popping noises when changing CD track. This depends on the HU and the RCA pre-out/RCA voltage.
  4. mordz
    mordz Audi S3 (2000)
    305
    i have both 408 and 410, the 410 is better if you have an amp with 2 RCA channels - as Andymac says, quallity is lower on the 408 (and quite noticable)
    im just using a sony HU and not had a any 'pops' yet.
  5. AndyMac
    9,832
    45
    The pop issue does seem to be totally inconsistent, some people get it some don't. If you don't get it then you won't get it.
    It seems to be more apparent on HU's that have a high pre-out voltage. Some of the tech info does state you should use the 408 if your RCA level is 4v or higher. It's to do with discharging capacitors on the input stage to the Bose/audi amps, and can only be eliminated by fitting capacitors to the RCA line - there was a write up on here about how to do this.
  6. stapo69
    969
    Lovely, cheers guys.
  7. mordz
    305
    btw If ya HU has only 1 RCA out you can use a Y splitter to hook up the other 2 RCA ins on the harness. Maplins sell some for £3-4
