Sorry completly non Audi question
tuffy Sep 4, 2013
  1. tuffy
    tuffy Member
    314
    13
    Hi guys, sorry but totally run out of ideas here.....ive just bought my mum a 53 plate cooper s, the central locking isn't working via the remote key button, but central locking fine with key being turned in the lock
    i've followed all the suggested methods ive found on google and Mini forums press the lock button 3 times then the unlock etc etc but they dont work!
    Does anyone know of someone in the Norfolk/Suffolk area that may be able to re sync the key to the car???
  2. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    Does the remote need a new battery?
  3. tuffy
    tuffy Member
    314
    13
    I have tried that but may be worth another change??
  4. rizzini7
    rizzini7 Active Member VCDS Map User
    974
    151
    43
    Tried pressing buttons with the key in the ignition??
  5. tuffy
    tuffy Member
    314
    13
    No buddy....tried turning the ignition on then off again, within 10 sec press unlock 3 times etc etc
  6. tuffy
    tuffy Member
    314
    13
    Just tried it.....no joy
  7. TOM.S
    TOM.S Active Member Silver Supporter
    551
    110
    43
    You'll need a new key from the dealer.. got the same issue with my B7 when i bought it.. it turned out to be a broken key. the chip/mechanism inside has broke and couldn't send a signal to the central locking system.
  8. Paul B7
    Paul B7 Active Member
    622
    34
    I had a similar issue on my wifes Yaris when I replaced the batteries in the key fob. The answer was to disconnect the car battery for two minutes , reconnect and BINGO !
    Not sure what happens but I guess the ecu resets itself somehow. Good luck.
  9. tuffy
    tuffy Member
    314
    13
    Thanks Paul ! I'll give that one a try. I read that the micro switches can fail inside the key. Found a service on eBay that will refurb the key with new switches , not sure if I'm comfortable sending the only key we have off in the post!
  10. GeoffDunk
    GeoffDunk Well-Known Member Team Panther Audi RS4 quattro Audi Avant Owner Group
    1,301
    390
    PM sent.
  11. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,819
    197
    3 button remote coded manually - Ignition into first position, or ignition ON, then remove key and press the unlock button and keep it pressed. Press locking button 3 times and release both buttons.
    2 button remotes are coded diagnostically, by an auto locksmith/dealer etc
    You are not local otherwise id help, all i can suggest is test the function of the remote if you can at a timpson or similar key cutting shop, if there is no function with a new battery then try replacing the buttons if damaged, or maybe a new remote.
    A good auto locksmith could provide a new remote key, but iirc the immobiliser and remote are on the same board so its not going to be cheap!
    Sorry I cant be of any more assistance!
  12. craigynett
    craigynett Member
    294
    10
    not true! there's plenty of people other than the dealers that have the equipment & are capable of doing these keys. They use the BMW EWS system. The transponder is separate to remote PCB & both are programmed in separately. With most aftermarket equipment the EWS immob module has to be removed from the car & the transponder programmed directly into it via eeprom. Then the 3 button remote is programmed with the manual procedure @udi_a3 mentioned. The 2 button remotes are programmed diagnostically using a barcode that comes with new key
    The batteries on these are also rechargeable & charge whilst in the ignition. The longest part of the job is removing the EWS module as it's fastened up above the pedals with anti tamper nuts so are a bit awkward to remove but can 100% be done
  13. @udi A3
    1,819
    197
    So the remote can be replaced without touching the immo? I read they were on the same board, must be a different system, this is why I dont touch BMW, so confusing!
  14. craigynett
    craigynett Member
    294
    10
    with genuine 3 button BMW/Mini keys the transponder is on the PCB unlike aftermarket keys. Not sure about the 2 button genuine keys as never looked inside 1 but again with aftermarket versions the transponder is separate.
    This is all just for the older EWS system. The newer CAS system is different. Transponder & remote program together by eeprom with aftermarket equipment. BMW/Mini come with 4 keys programmed into the system but only 2 are actually made. So when a customer requests a new key they just program the new key in the factory with info stored on database for say key no3. Then when the customer comes to collect it from the stealers it works straight away as it's id is already stored in the immob from when the car was built
  15. tuffy
    tuffy Member
    314
    13
    Thanks for your help guys, So just to clarify..... i have the two button key with the transponder fitted in the fob casing.....am i right in think that no form of internet based procedure ie.... turn key in ignition, press the lock button 3 times then press unlock etc etc will get this key to work remotely ????
    Do i need to find someone with the correct equipment to code it back??
  16. @udi A3
    1,819
    197
    Correct, and as you can see, whilst I can provide keys for some car, BMW/MINI are not my thing! Craigynett does sem to know a bit more about this than me maybe he can point you in the right direction? pm him.
  17. craigynett
    craigynett Member
    294
    10
    correct, 2 button remotes have to be programmed diagnostically with the barcode that came with it from new. I'm yet to meet a Mini owner who's car uses 2 button remote that still has the barcode. New 2 button remotes come with barcode for programming.
