Sony headunit into a4, b6
Quattro180 Oct 10, 2011
  1. Quattro180
    Quattro180 Member
    99
  2. AndyMac
    9,832
    45
    You'll need to pair the perm live & ignition on feeds as there is no switched live on the Audi loom. You will need the PC9-404 adapter to feed the rear RCA's to the Audi rear/sub amp (and connect the blue flying lead on this adapter to the power antenna feed from the Sony). Also the wraparound fascia adapter and antenna amp adapter:
    CT24AU03 Facia Plate for Audi A4 2000>
    CT27AA05 Aerial/Antenna VAG Active ISO Adaptor
    You will need to fade to rear quite a bit to get the puny 2 x 20w rear amp to match the 2 x 50w Sony output to the fronts
  3. Quattro180
    Quattro180 Member
    99
    would i be better disconecting the amp and sub all together?
  4. AndyMac
    9,832
    45
    Technically yes, but the sub does help. Rewiring the rears to the HU and adding a proper sub is the best way forward.
  5. regnix
    regnix New Member
    Does this mean just short the two across? I'm a bit new to fitting car stereos and would hate to fry something!
  6. AndyMac
    9,832
    45
    Yes you need to cut the unused yellow wire from the HU and splice it to the red wire (after the inline fuses if they have any) preferably by cutting the red wire and using a solid terminal block to join all 3 together or using a high gauge bullet connector with the yellow and red in one side and the original red wire on the other. The adapter cable should come with the male/female ISO power adapter so you can perform this surgery on the adapter rather than cutting the Audi loom or indeed the wiring from the HU (if it has any). The HU just needs two 12v sources in order to work. All you are doing is getting both of them from the single permanent live source on the Audi loom. You can't fry anything as long as the connections are insulated and solid. Don't use a crappy piggyback connector as this will be unreliable.
