something wrong with my clutch :(
rickparmar Nov 9, 2007
  1. rickparmar
    rickparmar Active Member
    2,322
    13
    Hello
    When i press my clutch pedal it doesnt come back to me, and when it is pressed in i can not put it in to gear...
    Has anyone got any ideas what the problem would be, and the costs involved
  2. jeffers999
    jeffers999 got boost
    390
    sounds like either your clutch master is gone or the slave cylinder ....
  3. rickparmar
    2,322
    13
    how do I check which one is gone. What type of costs am looking at. Thanks for the reply
  4. jeffers999
    390
    Is the clutch level ok ??
  5. Aky
    Aky Aky
    1,512
    When that happened to me it was a new flywheel time. You might get away with one of the cylinders but the slave acts as the clutch release bearing.
  6. jojo
    28,944
    3,598
    Time to go back to a 1.6 Rick :moa:
  7. Defratos
    Defratos You’re Dethpicable!!
    2,232
    Hey there Rick, how are you mate? Long time no see since GTI inter. Well I've had the same problem in the past, and it's only happened twice to me and both on very cold mornings. same thing happened came to press the clutch and it just stuck to the floor. Well try and just lift the clutch again with your foot from the underside, this should release the clutch peddle back to its original position. I never had to spend a penny and it's been over a year now with no problems.
    I'm surprised that more people don't encounter the same problem on here
  8. rickparmar
    2,322
    13
    Cheers peeps
    Just tried again in the car, kept pumping it, and bring it back up with my foot, seem to have done the trick for now, went for a spin seems ok
    Defratos cheers mate, just did that, but it prob mess up again in the morning, will just have to wait,
  9. Defratos
    2,232
    yeah I guess its just a matter of time. See what happens and if it keeps doing it or gets worse then probably best to take it to the garage, hopefully not
  10. HTC
    HTC Active Member
    3,428
    9
    Check for fluid loss.
    If its a prob with the master cyl then it a quick cheap fix.
    However, if its the slave cylinder, its a gearbox off job on the S3 unfortunately.
  11. Stewart
    Stewart Member
    705
    10
    I have a brand new clutch master cylinder, bought in error. Will obviously be cheaper than brand new.
  12. rickparmar
    2,322
    13
    Still not fixed, its alot worse then it was before,
    how do i locate the master cylinder, and does any one have any pics
    also is there any way of telling which one has gone ?
  13. Perplexer
    Perplexer Member
    239
    I had this a few months after I purchased the car. It only happened on really cold mornings.
    It was fixed under warranty and it was the clutch slave cylinder I think.
  14. rickparmar
    2,322
    13
    yup cold mornings, I think it could be the master cylinder but I need to find diagrams how to take it out. U sure it was slave and not master mate
