SOMEONE PLEAASE HELP IN CAR PHONE 3.0 B7 A4
Scottwilliamson Sep 9, 2012
  1. Scottwilliamson
    Scottwilliamson New Member
    I have recently bought the 3.0 A4 s-line and i am curious about how to get the in car phone operational. I need to order the holder and the phone and where do i get this from and what exactly do i need to order. ??
  2. phil_w
    phil_w Active Member VCDS Map User Audi A4 Audi Avant Owner Group S-line owners group Team Brill Red
    581
    53
    If you've got the phone prep youve also got Bluetooth so don't necessarily need the holder as long as you've got rns-e sat nav or multi-function steering wheel to control the calls...
    TurboJeff likes this.
  3. Scottwilliamson
    What do you mean by the phone prep? i dont have the sat nav but i do have the multi function steering wheel.
  4. phil_w
    581
    53
    I presumed by 'in car phone' you have the blank plate either on the dash or in the armrest?
  5. Scottwilliamson
    its the one in the armrest.
  6. phil_w
    581
    53
    Cool. Then should be as simple as turning on the ignition, scan for bluetooth devices on your phone- usually comes up as Audi-UHV or similar in the list. Default pin is usually 1234 - should pair with phone then you can make receive calls through the cluster using steering wheel
  7. Scottwilliamson
    excellent thank you very much i will go and try that right now and see how i get on and let you know what happens.
  8. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator Team V6 TFSI Owners Group Gold Supporter Team Tornado Audi S4 quattro Black Edition s tronic
    8,114
    2,568
  9. Scottwilliamson
    probably i have not read it little bit due to laziness and i was on here anyway!
  10. Chris Norman
    Chris Norman New Member
    19
    I was in the same situation last week. Get in the car and search with your phone. Passkey is 1234.
  11. Scottwilliamson
    Yeah I have got it to work now I was trying it before but putting 12345 as the pass key but 1234 worked fine. I was using an iPhone to do it with and to answer you still have to push the answer button on your phone or is there any other way.?
  12. phil_w
    581
    53
    You dial and answer using buttons on the steering wheel
  13. phil_w
    581
    53
    The left-hand thumb wheel pushes in as well as spins. Spin to choose from address book and push to dial. Push to answer a call too. Numbers/names appear in the DIS
  14. Scottwilliamson
    Excellent thanks very much
  15. fossie
    fossie Member
    207
    Stupid question but how do you know if its bluetooth or not, mines in the armrest.... i did a scan on me phone but it didnt pick anything up!!
  16. phil_w
    581
    53
    As far as I'm aware as I've never come across one that isn't - Bluetooth and phone prep always coexist as the phone module is standard and only difference is that phone prep includes a physical cradle.
  17. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    The very earliest Audi phone module (in 2004) didn't have Bluetooth, but there's very few of them around - so it's a fair assumption that if there's a cradle you have Bluetooth.
  18. PetrolDave
    1,559
    85
    The Bluetooth is only discoverable for a short time after turning the ignition on, so you have to turn the ignition on and then search for and pair with it straight away.
  19. Scottwilliamson
    does anyone know where you can get the phone that sits in the cradle ??
  20. Dannykn9
    Dannykn9 "Cruise My Ride" VCDS Map User
    1,123
    56
    You buy the cradle that suits "your" phone, ie..if you have an iPhone, you buy the iPhone cradle.
    Cradles can be bought from the dealers for around £100.
  21. Scottwilliamson
    Where about can i get this iphone cradle ? You are speaking about the cradle that is in the armrest?
  22. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group S-line owners group
    3,692
    640
    Your local Audi dealer, or a forum sponsor Stoke Audi
  23. Dannykn9
    1,123
    56
    I think your a bit confused mate.
    The plate in your armrest, is what the cradle attaches to.
    So as said, you need the cradle that suits your brand phone, and as advised already by me and B5NUT, you can buy it from your local dealer, or from Stoke Audi on this site.
    Hope that helps fella.
  24. jdp1962
    8,114
    2,568
    Or you could just read your owner's manual, as I think I mentioned about six months ago.
