Some Videos Of My S3 8P
david_phillips95 Mar 8, 2010
  1. david_phillips95
    david_phillips95 Member VCDS Map User
    504
  2. warren_S5
    warren_S5 Moderator Staff Member Moderator VCDS Map User
    7,210
    2,483
    Sounds good.
    How are you finding it?
  3. david_phillips95
    504
    When i first fitted the downpipe i didnt think the perfromance gain would be that noticeable..i was wrong, the turbo started spooling lower down in the rev range and was pulling far harder than before. This was all noticed when running Revo Stage 1, now im running Stage 2+ its scary fast at times - i have found myself running out of road and having to lift off on parts of road where i used to run WOT. In higher gears above 5k RPM when your pushing the car on and lift off you get a dull popping from the exhaust which i LOVE. The system is as quiet as OEM when your driving normal but when you open the throttle up it roars. Great product many thanks to MV Sport :icon_thumright:
    Davie
  4. warren_S5
    7,210
    2,483
    Ditto, I was astonished. I was expecting one of those placebo type improvements, but the OEM DP/cat is designed for plushness, certainly not performance. It's a pleasant surprise to spend money and get some decent reward in return.
