some vagcom questions
thomp1983 Aug 15, 2006
  1. thomp1983
    thomp1983 New Member
    17
    hi i bought an autonostics cable from ebay and have a registered copy of vagcom 311.2-N
    when i go to select control module then choose module 01 engine i nearly always get the error no response from controller or occasionally get baud can't sync error. what causes these issues and how do i solve them? the car is a '98 ahu engined a4 tdi.
    thanks
    chris
  2. madvw
    madvw Active Member
    2,489
    is the cable a serial cable, or a usb->serial cable? what are your serial port settings?
  3. thomp1983
    17
    serial cable
    chris
  4. dummi
    dummi smoking a6
    1,210
    have you an aftermarket radio? there are problems with k-lines on aftermarket radio adapters '97<
  5. thomp1983
    17
    i do at the minute, but the problem happened with the factory stereo aswell
    chris
  6. dummi
    dummi smoking a6
    1,210
    check ross-tech.com they may be able to give you support because you are registered, but i'm not sure about for v409>
  7. Tallpaul
    Tallpaul Member
    835
    Ross-Tech get all pissy with support if you're not using one of their official cables.
    Are you using a Serial-USB converter to plug in your cable?
    Have you tried switching COM ports in Devices on Windows and on VAG-COM?
    Have you played with the Baud rates for the COM port on Windows?
  8. Sebastian
    Sebastian Member
    286
    We get "pissy" because the 3rd party hardware vendors are too cheap to put high quality components into their hardware and they usually don't give support to their customers. These "customers" then blame us for bad software, but let's get real here - this is not a software issue.
    The described issue really sounds like a hardware problem or a problem with your notebook hardware. We have seen some "lame" notebook ports that result in errors like this.
    Read these pages and try whatever they tell you.
    http://ross-tech.com/vag-com/faq_2.html#2.4
    http://ross-tech.com/vag-com/faq_2.html#2.5
    http://www.ross-tech.com/vag-com/issues.html
    Also try playing with the power supply of the notebook, if you are running on battery, try with a real power supply and vice versa.
    If neither of this works, try a "real" interface.
  9. thomp1983
    17
    tbh the laptop im using is a bit old, im using the cable with a proper serial port no adaptor involved and the laptop is plugged into the mains, ill have a play with the settings which i suspect to be the cause
    cheers
    chris
  10. Sebastian
    Sebastian Member
    286
    Please define "a bit old" with some more real details. Processor? RAM? Operating system?
  11. thomp1983
    17
    166mmx processor, 64mb of ram running windows 98
    cheers
    chris
  12. dummi
    dummi smoking a6
    1,210
    ^^thats more than enough.
    if all else fails do look into the radio connection, i didn't realise it for a while but i had that problem.
  13. madvw
    madvw Active Member
    2,489
    Too true. Some laptops simply do not ouput the right stable voltage on the ports to enable reliable communication. Some older DELL laptops unfortunately fall into this category...
  14. Tallpaul
    Tallpaul Member
    835
    See told you Ross-Tech don't like it :biggrin:
  15. Sebastian
    Sebastian Member
    286
    Not perfect, but should be enough. Now what I would do is double check with a different notebook and if this doesn't help, get some real hardware.
    See, what I often ask people in cases like this is "What's your hourly wages at work? How many hours did you waste now?" - guess you know where this goes.
  16. Tallpaul
    Tallpaul Member
    835
    To be honest, if you look at the context of my original post it was in response to somebody saying contact Ross-Tech for support. I was pointing out that as the user didn't have an official ross-tech cable, it was unlikely that they would offer any support. I then went on to offer some suggestions based on my own epxerience of non-official cables.
    I don't care how much you get paid, i'm always appreciative of good advice and have found other employees of Ross-Tech (particularly 'Uwe' who posts on other forums) to be very helpfull.
  17. bearthebruce
    bearthebruce Ross-Tech, LLC
    343
    21
    As said, this should do the job with a serial cable. You may have to play with the baud settings for it to work with your engine controller. I don't recall seeing which engine you are having trouble with but some controllers are known to be finicky on timing in the communications. You will just have to play around to see if you can make it work.
    To TallPaul: Ross-Tech is comitted to helping people use our products. Frankly, most of us spend our "free" time supporting these forums. There are so many threads dealing with the subject of aftermarket cables that it gets old for us. But you may have a point. We do tend to act "pissy" when being asked the same questions over and over and over. The aftermarket cables are "cheap" for a reason. They do not put the hardware needed for reliable communications in their cables. Then, they do nothing to support their customers. So, yeah, Ross-Tech grows weary of loosing business to these guys and still being expected to lend a hand when they don't work. Perhaps you can understand the frustration.
    Uwe, the owner of Ross-Tech and creator of VAG-COM, is indeed a patient man and loves to offer support and help. Thanks for the kind words said about him and the product.
    -Bruce-
    Director of Operations
    Ross-Tech, LLC
    Bruce@ Ross-Tech.com
  18. Tallpaul
    Tallpaul Member
    835
    Thanks Bruce.
    Just to clarify my position; I'm fully aware that the issues of using non-official cables is age old and that throughout the many VAG forums their problems and possible solutions has been discussed ad infinitum.
    Obviously using the term 'pissy' hasn't gone down too well :no:
    I was in no way implying that Ross-Tech's user support is anything less than fantastic (i know first hand that it is outstanding). I was mearly trying to disuade somebody from going direct to Ross-Tech when there should be more than enough knowledge available through this forum to rectify their issue. :biggrin:
  19. thomp1983
    17
    it's the ahu 1.9tdi engine
    chris
  20. bearthebruce
    343
    21
    I'm not aware of any timing issues with that engine controller. I suggest you follow the advice given and play with the baud rate on the Options screen to see if you get better results. Or, as has been suggested, contact your cable vendor for more support.
    Best,
    -Bruce-
    Ross-Tech,LLC
    bruce@Ross-Tech.com
