When I turn my engine off and get out my car. There is some Sort of fan that still runs. It goes off if I start the car up again. Any idea What this could be
Yeh, if it doesn't happen all the time, most likely the dpf has been regenerating. This has happened twice for me so far. There was also a distinctive smell too iirc.
Mine used to do that, there are two fans one for aircon and one for rad. One of mine wasn't working so the other was working overtime. Have a look and check that they both work. Mine used to run after the engine switched off but since I got the other working it never happens anymore
OP you'll probably find your engine idles a bit higher than usual too and if you've got the gear suggestion on the DIS it will tell you to drive in a lower gear than usual.
Affirmative.
Whenever I notice the gear change on the DIS being funny I know the dpf is trying to regen. so I try to change my route where it can do so. Once the Start-Stop is working again, I know the process is complete.
