Some MP3s Won't Play?
Simo_UK Apr 1, 2012
  1. Simo_UK
    Simo_UK Member
    37
    Hi All,
    Haven't managed to find an answer to this so far. Maybe you guys can help me out. :eek:)
    I have a number of MP3s loaded onto an SD card. The bit rate, file format and max number of files thresholds are all within limits.
    However, when I try to play some files, they are jus skipped by the MMI and won'r play. No error, then they appear grey on the screen.
    Any idea? The files play fine elsewhere.
  2. johnnythepie
    johnnythepie Well-Known Member
    2,242
    75
    I had exactly the same with an ipod classic...and i ended up getting rid cos the replacement was the same.This told me it was a hardware issue.You should copy your stuff from the sd card into a folder on your hd, then reformat the sd card, and error check.Run your mp3's through foobar to re encode them, and put them back on the card.Failing this, try a new sd card
    foobar2000
  3. MartayMcFly
    MartayMcFly Booooooost VCDS Map User Gold Supporter
    2,763
    354
    I assume this is an RNS-E?
    Double check the file format of the songs being skipped as the unit won't recognise every file version, and make sure the file names aren't too long (not sure the limit there, but apparently the systems don't like long file names).
  4. Simo_UK
    Simo_UK Member
    37
    Will give it a go an let you guys know.
    Thanks for the tips!
  5. dstech
    dstech Member
    247
    Double check the files with this software called "Mediainfo". You might find out that some are not constant bit rate and are actually variable bit rate and thus the max bit rate will jump higher than the allowed max bit rate. If you just view the files using a normal media player or by using windows explorer they often will not show you the max bit rate. That's why you need the special program to find this info out.
    MediaInfo
