Some more goodies for the Ess.
jojo Oct 23, 2013
  1. jojo
    jojo Looking for Boost! Staff Member Moderator Team Daytona quattro Audi S3 Audi A6 Audi Avant Owner Group
    28,826
    3,479
    Just got back from VW and the powder coaters.
    New front ARB and OEM bushes.
    Freshly powder coated front arms/subframe, clamps and bush holder thing.
    034 subframe bushes. :)
    And some poly bushes, which I didn't bother taking a pic of.
    I had no intentions of polybushing my front end, but I managed to get the whole shabang for a bargain, so was hard to say NO, it's basically a complete lower front suspension rebuild, which should outlast the car hopefully. I have new drop links aswell, and I need to get some new lower balljoints, then find a nice day in the next 12 months to fit it all! :laugh:
    s3dave and Jason.s like this.
  2. Sam_
    Sam_ Down under
    3,029
    477
    Steering rack mount? The solid one seems good.
    What ARB is that?
  3. jojo
    28,826
    3,479
    Yes, need a new one of those too, going OEM, I don't see the benefit of a poly item there.
    ARB is a 21mm one. ;)
  4. Sam_
    Sam_ Down under
    3,029
    477
    Fair play. Steering feel is improved (mines solid mounted). VW obviously saw benefit, the MK5/6 are both solidly mounted racks without the bush.
    Blimey, what size rear? 22? 24? I can't seem to find anything bigger than 20mm rear here :(
  5. jojo
    28,826
    3,479
    19mm rear
  6. Sam_
    Sam_ Down under
    3,029
    477
    Not worried about under steer?
  7. Jason.s
    Jason.s Active Member
    2,879
    348
    Hope that 21mm bar is right. Looks alright. Was just a bit sceptical going for a bar no ones fitted. Especially someone else doing it. I dont mind doing it myself as it doesnt cause anyone hassle if its wrong and i can send it back easy lol.
    Just need a 23mm rear now.
  8. jojo
    28,826
    3,479
    Why would a 19mm rear cause understeer? If anything, it makes it oversteer, like in my avatar. I'm trying to balance my car with this ARB setup based on my current suspension setup and geometry.
  9. jojo
    28,826
    3,479
    I will find out soon enough, if it doesn't fit, then the 19mm is going back on Jase.
  10. Jason.s
    2,879
    348
    It oversteers when you lift off or you have crappy Avons on it Jo haha.
    Only once has my kicked out on r32 rear bar and that was with Avons :p
  11. superkarl
    superkarl MAN OF STEEL
    9,329
    2,333
    look forward to a review jo, i wouldnt mind some solid subframe mounts and bigger arbs F and R
  12. Sam_
    Sam_ Down under
    3,029
    477
    Not the 19mm rear. More the larger front than rear was what I was getting at.
  13. jojo
    28,826
    3,479
    I had Falken 452s on the rear in the clip Jase, and when they see water, they are shyte!
    I drove Rhubarbs fully polished example, and it did feel tighter than mine all round, without being harsh to be fair, but he did have standard suspension and ARBs
    I'm currently running 19/19, needs a bigger front to make it more neutral, back end has TOO much grip atm.
  14. A3-Lee
    A3-Lee Active Member VCDS Map User
    938
    226
    43
    Happy days mate I haven't forgot about you just had a load on be In touch soon
  15. jojo
    28,826
    3,479
    No worries Lee, and no hurry neither, we both know what's priority mate. ;)
  16. kwistof
    kwistof South East Events Moderator Regional Rep
    2,434
    534
    I found the same problem tbh....only managed to 'fix' it by changing the front tyres to the rears to make it more interesting and predicatable through the corners (less tread now on the back).
    If this set up works for you I think I may follow in your footsteps come spring time as I'll be needing 4 new tyres and so I'll be getting grip overload again at the rear.
  17. Jason.s
    2,879
    348
    Or could always step down on the rear arb to a 16mm?
  18. kwistof
    2,434
    534
    What's the standard rear ARB on the S3 again?
    Joe- have you changed the engine mounts if you're giving the whole front end a refresh? Or are they in decent nick?
  19. Jason.s
    2,879
    348
    14mm was standard. 19mm was R32. Theres also a 13mm and 16mm. Guessing maybe the 16mm was from the 4mo 2.8 mk4.
    kwistof likes this.
  20. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Didn't they do 14mm and 15mm in standard and Gmbh form? I'm sure mine was 15mm when I removed it.
    Either way Jojo, your driving style must differ to mine as I'm thinking about going larger than 19mm at the back. This could be because I'm used to driving the Pug in summer which has a 24mm rear ARB though :eyebrows:
  21. RobinJI
    RobinJI Active Member
    176
    26
    Adding a larger front ARB will give the front less grip and the rear more. If you've got too much rear grip you need to downsize your front or increase the size of the rear ARB.
    Running a stiffer ARB resists roll by pushing the outside wheel into the tarmac harder, causing more weight transfer at that end of the car and therefore less grip on that axle. As the car's total weight transfer isn't effect by roll resistance, this in turn causes less weight transfer and therefore more grip at the other end of the car. It's why hugely front heavy FWD cars always run huge rear ARBs.
    Jason.s likes this.
  22. jojo
    28,826
    3,479
    Original engine mounts, just a poly dogmount.
  23. jojo
    28,826
    3,479
    It's hard for me to explain, but the balance of running 19/19 F/R is not balanced, the back end is snappy, especially in the wet! I need to the front end to be tighter to counter balance the back end, but like with everything else, mods on cars are subjective, not very mod is for everyone, so going 21mm front is a trial in itself, so let's see if it works, for MY suspension setup, and MY driving style.
    s3dave likes this.
  24. A3-Lee
    938
    226
    43
    But very low mileage remember lol
  25. RobinJI
    176
    26
    That's cool. I wasn't trying to say anything was right or wrong, just making the actual dynamic effect of changing ARB's clear. :) I'm all for having a play and seeing what happens. It'll be interesting to see how you get on.
    Personally I've found that running a large rear ARB on my car has made the back end more predictable. It's more likely to step out than it did with the old smaller one, but when it does it's a much more predictable and progressive loss of traction, it doesn't snap in the same way it could before, and the overall grips been increased because the front's not washing out. (Running 19mm front 25mm rear, not that a Scirocco's comparable anyway!)
    Good wheel control's essential for predictable and controllable handling; if the back end's snappy it could worth looking at killing as much flex as you can back there. What bushes are you running out back?
  26. Jason.s
    2,879
    348
    I don't find it snappy at all tbh. You must turn in sharp all the time? Get some quality tyres man! Lol. How's your alignment? Think I've got 1.4 on the front which is max on standard wishbones. Rear is 1.6 as the tie bars got stiff lol. Wouldn't mind some top mounts to dial in a bit more on the front.
  27. Gops
    3,190
    648
    What are my arbs jo? I can't remember what size they are!
  28. jojo
    28,826
    3,479
    You don't have my suspension setup though, no one does, having uprated ARBs is one thing, but it has to work with the suspension/wheels/tyres! I will get my car to how I want it eventually, but it's a lot of trial and error, the 21mm front ARB is the next step, as I've tried the 22mm setup already!
    22/19 neuspeed arbs you have Gops! The specs on your car when I got it was basically the custom setup EssThree did on his car many years ago, and it works!
  29. vfr800
    vfr800 Active Member Team Dolphin Grey quattro Audi S3 Audi A6
    773
    57
    Hi JoJo
    Where'd you get the coating done? How much did it cost?
    I need to get exactly the same done to my spare subframe and wishbones etc.
    Ta, Liam
  30. jojo
    28,826
    3,479
    City powder coaters in Birmingham.
  31. Westy
    Westy Well-Known Member
    17,440
    1,097
    Joe. Are you getting the adjustable arbs? They Will help you fine tune your setup. I'd expect the difference in a 19" rim compared to a 17" rim would make quite a big difference to the handling.
  32. jojo
    28,826
    3,479
    No mate, 21/19 is the setup I'm going for, there's a reason for it, but I will explain later. I'm currently running 18s, which is the best size for handling from my experience. My 19s use to be good, but it doesn't work with my current suspension setup, which is why I've put them up for sale.
  33. Westy
    17,440
    1,097
    Smaller the wheel the bigger the tyre profile which will be a lot more forgivng as it flexes in corners. The bigger your wheels the thiner your tyre profile gets and less tyre wall movement.
    Jason.s likes this.
  34. jojo
    28,826
    3,479
    It's a weight thing too, BBS 18s are much lighter than the 19s I have, and with the corrected camber I have on the back, the 19s now catch slightly under load!
  35. Westy
    17,440
    1,097
    Oh of course, but adding weight anywhere will effect cornering ;)
