Some error codes
0w3n Jun 7, 2008
  1. 0w3n
    0w3n New Member
    21
    After getting some help fromI have just bought an Audi S4 B5 1999.5.
    After some initial issues getting the VAG COM cable to work I now have some errors I need some help with.
    Im assuming its something to do with my O2 Lamda sensor.
    VCDS Version: Release 805.0
    Data version: 20080529
    Saturday,07,June,2008,19:19:43:01254
    Chassis Type: 8D - Audi A4 B5
    Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
    Mileage: 203220km/126275miles
    Address 01: Engine Labels: 078-907-551-AZA.lbl
    Part No: 8D0 907 551 C
    Component: 2.7l V6/5VT 0002
    Coding: 05611
    Shop #: WSC 00066
    3 Faults Found:
    17978 - Engine Start Blocked by Immobilizer
    P1570 - 35-10 - - - Intermittent
    17865 - Exhaust Gas Temp Sensor 2 (G236): Open or Short to Plus
    P1457 - 35-00 - -
    17861 - Exhaust Gas Temp Sensor 1 (G235): Open or Short to Plus
    P1453 - 35-00 - -
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: 8E0-614-111-EDS.lbl
    Part No: 8E0 614 111 A
    Component: ABS/EDS 5.3 QUATTRO D10
    Shop #: BB 24334
    No fault code found.
    Address 08: Auto HVAC Labels: 8L0-820-043-2D.lbl
    Part No: 8L0 820 043 D
    Component: A4 KLIMAVOLLAUTOMAT_D75
    Coding: 04161
    Shop #: WSC 06335
    Address 15: Airbags Labels: 8D0-959-655-AI7.lbl
    Part No: 8D0 959 655 L
    Component: Airbag 7 Audi 0503
    Coding: 00104
    Shop #: WSC 06335
    Address 17: Instruments Labels: 8D0-919-xxx-17.lbl
    Part No: 8D0 919 930 KX
    Component: B5-KOMBIINSTR. VDO D17
    Coding: 00464
    Shop #: WSC 00262
    Part No: IMMO
    Component: IDENTNR: AUZ7Z0A2010910
    IMMO-IDENTNR: AUZ7Z0A2010910
    Address 35: Centr. Locks Labels: 8D0-862-257.lbl
    Part No: 8L0 862 257 G
    Component: ZV-Pumpe, DWA, Funk D08
    Coding: 13130
    Shop #: WSC 06335
    Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
    Part No: 4B0 951 173
    Component: Innenraumueberw. D03
    Coding: 00101
    Shop #: WSC 06335
    Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
    Part No: 4B0 907 357
    Component: LEUCHTWEITEREGLER D002
    Coding: 00004
    Shop #: WSC 06335
    End ---------------------------------------------------------------------
  2. Broken Byzan
    13,237
    465
    EGT sensors on the exhausts, common failiure so i am led to believe
  3. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,775
    33
    Not cheap to fix, but it will be running good once you've sorted them!
  4. stapo69
    stapo69 All hail the mighty quattro!
    969
    Vagparts do em for a reasonable price, but still around the £140 mark, each. Drivers side is easy to fit, can do it from the top of the engine bay, EGT1. The passenger side however, EGT2, is more of a pain in the ****, really need it on a 2 poster or summit similar for this as you need to get it from under the car, but it's buried a fair way in.
    Have a look here for fitting clues:
    http://www.audiworld.com/tech/eng73.shtml
    However it may be worth clearing the codes and running the car for a bit, just to make sure they're not old codes and the work's been done.
    Although if they are knackered it'll be like driving a new car once you've fitted em!
  5. 0w3n
    0w3n New Member
    21
    cool, thanks for your replies guys. i shall get the pennies together and replace them myslef, my mate works at the local garage so getting underneath it will be no problem..Will let you know how i get on!
    Thanks Again
    Rob
  6. 0w3n
    0w3n New Member
    21
    ordered the part today from VAG Parts. £112 each - not bad compared to stearler who wanted £169 each! also bought 2 Bosch 710N DV's. These seemed to be a common DV to use other than a forge or Bailey...I will run with them and see if i want to fork out the extra for some shiny ones!
