Solved a couple of problems and caused another !
basil brush Apr 8, 2013
  1. basil brush
    basil brush Active Member
    476
    145
    43
    Hi all , had a day off today so tackled a couple of issues , changed a dodgy temp sensor , changed a temperamental crank sensor and cleaned my throttle body and am now left with an idle speed of 1500rpm which does eventually settle down to 1000 !
    Got a code of 00515 cam sensor but it had that before !
    Its a 1.8t agu
    any ideas ?
  2. jay1601
    jay1601 Well-Known Member
    1,304
    51
    did you reset the TB after you cleaned it ?
  3. basil brush
    476
    145
    43
    Errrr sort of !
    I follower the reset I found in a google search ,
    dissconnected negative battery lead for 15 minutes , reconnected , turned ignition on and left it until throttle body had stopped making noises , pulled key out , shut bonnet then started !
    If that's rubbish please don't laugh :) lol
  4. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,244
    350
    think it automatically resets after a few miles of driving
  5. basil brush
    476
    145
    43
    i do hope so ! It's driving me mad :0
    i have the fault code as I have an obd2 reader but would like vcds , would the free version of lite allow me to do a TB re alignment ?
    As for £7 for the generic lead off the bay may well be worth it ;)
  6. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,183
    Vcds lite doesn't allow for tb alignment.
    It does a basic alignment when the ignition is live, you don't need to have a door open, interior light on, boot open, depress the throttle four times or hop on your foot. It just does it.
  7. basil brush
    476
    145
    43
    cheers fella , no vcds for me then ! Will this idle issue sort itself then or do I need to find a friendly vcds owner ?
  8. vfr800
    vfr800 Active Member Team Dolphin Grey quattro Audi S3 Audi A6
    773
    57
    er ... Yeah it does, I swear I could do the TB alignment when I cleaned mine last year. I did pay for VCDS lite though.
    liam
  9. phil miller
    phil miller Well-Known Member VCDS Map User
    1,211
    166
    Paid for does, Freebe doesnt :)
    ive got the full VCDS hex+can so i can do ANYTHING :)
  10. basil brush
    476
    145
    43
    Yeah but your in Devon and I ain't ! Lol
  11. phil miller
    1,211
    166
    Great Reply :)
    edit your location dude :)
  12. basil brush
    476
    145
    43
    done just for you ;) lol
    so when you popping up to reset my TB pmsl
    phil miller likes this.
  13. phil miller
    1,211
    166
    Lol, hmm im sure there is a member near to you that will do it, atm im not planning on being up that way in the near future, if i was id reset it for you not a problem dude
  14. 16Klappe
    5,795
    1,183
    Nope, no free version of VCDS will let you go from measuring blocks to basic settings. VCDS Lite is simply a data logging and fault code tool.
  15. vroomtshh
    vroomtshh Active Member VCDS Map User
    362
    There is a free version of VCDS Lite and a paid for version. The paid for version lets you do a throttle body reset. Its still VCDS Lite
