Hi Everyone,
ok, so here's what happened.
a couple of weeks ago i went to put new rear pads on my car, while doing that i noticed the rear pistons were pretty siezed. ordered new (refurbed) callipers from eurocarparts.
at the weekend i went to fit the new callipers, the first one i put on i was the offside, i went to bleed it and eventually realised that the bleed nipple wasnt closing. turns out the thread in the calliper was stripped.
in this time of messing around quite alot of fluid dripped out :-( to the point where i dont think there was any left in the pipe or header tank.
I got the calliper replaced and put on the 2 new callipers and bled both back brakes alot using an eazy bleed.
The pedal felt nice and hard with the engine off, started the engine and it was all soft and squishy.
i then bled all 4 corners and got a few air bubbles out the front left.
pedal is still soft with the engine running. it does brake gradually as i press the pedal and if i jump on the pedal the anchors are out and it brakes pretty well. only problem is the pedal feels light.
any suggestions on what could be causing it?
