"Soft" limp mode VS "Hard" limp mode
Scullies Apr 2, 2013
  1. Scullies
    Scullies Well-Known Member
    1,543
    657
    Was wondering what the differences are between the above limp modes and what triggers them.
    Awhile back I was getting an over boost fault, resulting in the boost running at 5psi. It could only be cleared by erasing fault codes.
    Is that a soft or hard limp mode?
  2. phil miller
    phil miller Well-Known Member VCDS Map User
    1,211
    166
    tbh there is only one limp mode, but say your lambda sensor is fooked yes you are in a sort of limp mode but apart from the light being on you prob wouldnt notice, yet the over boost you would notice
  3. beachbuggy
    beachbuggy Well-Known Member
    1,931
    201
    Do you mean over boost, under boost limp mode? The Ecu has 2 pressure deviation maps that once triggered will set dtc's. there are other pressure protection maps , timing protection etc but the car needs to be pretty bad for them to trigger.
  4. badger5
    9,490
    1,999
    what map are you running on what hardware currently? Your original?
  5. Scullies
    1,543
    657
    I was running the remap, but I was getting very high boost spikes with the large K&N filter. I went to the guys that did the remap, but he wasn't very helpful. His answer was its impossible for the turbo to use more air than the map is asking for. :wtf:
    So I have put the stock map back on now as its getting hot, hitting 35 during the day.
    My question was more of an information question, as I have seen a few posts about "soft" limp mode and thought it was different to a "hard" limp mode.
    I was wondering if different safety measures throw you into different limp modes. As I know if the actual boost vs requested boost differs by too much - you get a "hard" limp mode, that needs to be reset with VCDS.
    Been on the nef site trying to educate myself in this ecu stuff, I was enjoying the tuning steps you were sending me for my BT setup. My wife though I was crazy tho, when I was loading files and trying to explain to her how things were changing. I might have refered to it like giving birth and watching your child grow up. :redface:
  6. Vex182
    Vex182 Guess what I drive...
    1,035
    79
    I THINK "soft limp" is when the car dumps boost if possible, by using the n249 and this will not cause a fault code to be saved.
  7. badger5
    9,490
    1,999
    What hardwares on your car currently?
  8. Scullies
    1,543
    657
    1.8 k04, 600x300 FMIC & 3" piping, 3" downpipe (custom homebrew :sly:), Large k&n filter, forge 007p, silicone tip. stock fueling setup. Even with the stock map the boost gauge is reading 1 bar max with the k&N, when I had the stock air box and flat panel k&n filter boost was at .8 bar.
    So I assume the large filter is the cause for more air flow.
  9. JUS3IN
    JUS3IN 14.0 @ 98mph 2s 60ft
    1,159
    102
    soft limp will reset itself but log a code. hard limp on my apy i think i got when i disconnected my injectors and cranked her over to prime the turbo i'd just changed.... never got an engine light but wouldnt boost at all until i'd reset it by disconnecting the battery.
  10. AdamNajak
    AdamNajak New Member
    10
    The dreaded Limp mode :/ 3 months and still havent managed to solve mine :(
  11. JUS3IN
    1,159
    102
    do you have a chinese turbo? thats what was causing mine, had to have it off and send it to bill at badger 5. do you get boost creep if you bypass (link charge pipe straight to the actuator) the n75? i was still gaining boost once i done this= bad...
  12. Sam_
    Sam_ Down under
    3,038
    480
    Limp mode in an S3 is like a K03s has been fitted
  13. Gops
    3,198
    666
    I went into limp mode when my throttle triggered a code. It wouldn't rev or go over 5mph! Cleaned the TB and cleared codes, runs like a dream :)
  14. S3DTP.
    S3DTP. New Member
    9
    Haha Sam_ agreed, I'm limping now and would still give a few cars a decent run ;)
