So, i bought a 170 TDi with DPF
WilkyA3 Mar 18, 2012
  1. WilkyA3
    WilkyA3 Active Member
    101
    Yeh it seems to be a well talked about topic! I'm well aware of the issues that i can be facing with DPF, i face a 33 mile round trip to work daily, consisting of national speed limits and a duel carriageway so i think my journey is not going to be an issue!
    My question is regarding what i do now as the new owner, do i just get in and drive it as normal? or do a bit of hard driving incase the previous owner was a short journeyer. I guess i'll be giving it the odd thrashing but nothing major. I bought it from a dealer but not an audi dealer and obviously i was assured there's nothing to worry about!
    Cheers,
    Wilky.
  2. cloughy
    cloughy Member
    515
    You'll be fine with that journey, very similar to mine, plenty of opportunity for the DPF to do a regen
  3. Sandra
    Sandra Administrator Staff Member Administrator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter
    26,665
    9,655
    Welcome to ASN. Hope you enjoy the car and the forum. :)
  4. Adam.
    Adam. Meow.
    662
    34
    You will know if the car needs a re-gen as it will idle at 1k instead of 750-800rpm.
    If this happens then just keep it above 2k untill it settles down!
    I used to do 38 miles each way to work in a 170 and never had an issue. Infact my 2 previous cars on that commute were 170s.
  5. Rhyso
    Rhyso Well-Known Member
    1,494
    307
    Get the injectors done under the recall ASAP if they haven't already been done
    Other than that you should be fine. DPF's tend to fail because the sensors fail and the DPF can't regenerate.
    My car has done 44K now of which I've done 20K of them and 12K of those have been remapped and so far so good..........
  6. WilkyA3
    101
    Cheers folks. Off to Portugal with work or 2 week then I will be picking it up. Getting slightly impatient now!
  7. flying oyster
    flying oyster flying oyster
    563
    27
    drive it like you stole it no dpf problems then
    Charles Tait likes this.
  8. RedDejavu
    RedDejavu Well-Known Member
    1,806
    337
    just get the bugger cut out and put stage 2 in:D
  9. audigex
    audigex Active Member
    594
    45
    Mine seems to sit at 2,500 rpm on a motorway/a-road cruise, so presumably it will regen if I just drive on the motorway for a while. About how long will it take at that sort of engine speed to regen?
    I should be using the car on a 50 mile each way (ish) journey often enough to avoid problems - it's more like once a week/fortnight than a daily drive though. This is pretty much 20 minutes of motorway cruising, 20 minutes of dual carriageway cruising and 20 minutes of slow-fast a-roads... then the reverse to return. Can anyone see any likely problems with this?
  10. RedDejavu
    1,806
    337
    I used to do 10 miles a day town driving and have had no problems so you'll be ok!
  11. Sidhu88
    Sidhu88 Active Member
    808
    76
    If the car feels fine i'd be pretty skeptical about the recall work. It seems a few people have had more problems after the recall than before. I defo have.
    M88UES likes this.
  12. SWILKO
    SWILKO Member
    105
    Yeah, mine came back from Audi with an oil leak due to them not replacing the rocker cover gaskett...
    Plonkers!
  13. M88UES
    M88UES Theres Never Enough Power
    60
    Yeah , i am also one of these. Recall has made mine worse and still havent got it sorted yet as they cant find fault apparently.
  14. Rhyso
    1,494
    307
    Guess I'm lucky then as mine improved no end and gave me an extra 4.1bhp :D
    I do have a mate though where they replaced the injectors on his A4 and didn't fit an o-ring properly; ended up with fuel mixing with the oil............
