So, had an S3 8P stage 1 remap...problems.
cshy Dec 17, 2012
  1. cshy
    cshy New Member
    12
    I will bullet point to keep it simple
    • VAGCOM plugged in showing boost valve error (N249 valve)
    • Guy thinks it may be an old error and does it again and the code doesn't show
    • Remap done to 305
    • Notice at 4k revs the power drops off with no engine management or any other lights, as if the wheels are spinning
    • I go back to garage and tell the guy this, he plugs in laptop and the error shows up again so have bought a new N249 valve to get replaced on thursday elsewhere
    With what is happening, could this be the problem? Or is there something that's not obvious you guys will know about?
  2. Tay
    Tay Active Member VCDS Map User
    449
    55
    Do you have an uprated diverted valve?
    The power drop off could be hesitation due to a number of things such as spark plugs, coil packs etc...
  3. PaulAr
    PaulAr S3 (8P)
    4,073
    186
    Do your revs rise but no increase in speed ?
    Is it more obvious coming on boost in higher gears?
    If so, it sounds like your clutch mate.
    Common on remapped VAG 2.0TFSI, Ive had this happen twice on Stage 1 cars.
  4. cshy
    cshy New Member
    12
    No the revs dont go past 4000
    No uprated valve as far as I know. Just wondering if this is the problem considering it's showing up on VAGCOM
  5. Boydie
    Boydie S3 8V DSG VCDS Map User
    3,450
    588
    First thing I thought was clutch but if it doesn't go past 4k then there must be a restriction of some sort.
  6. KentKid
    KentKid Active Member Team Ibis TFSI Owners Group Audi S3 Manual
    179
    74
    I didn't realise the clutch could have a direct affect on performance like that.
    I'm running Revo Stage 2+ with the standard clutch, and I haven't had any problems whatsoever.
    That said, and after reading your post, I can't help but wonder if an uprated clutch might lead to a noticeable increase in performance despite my S3 being problem-free so far...
  7. DeckedS3
    DeckedS3 Well-Known Member
    868
    298
    Does it kit 4k hard and pull back/stop or rev up to it slowly like limp mode?
  8. cshy
    cshy New Member
    12
    Can redline in 2nd and 3rd but 4th is/seems normal up to approx 3.5/4k then loses power so need to change up a gear.
    N249 valve has been changed and still being logged as an error :-(
