snapped S3 rear spring / coil
S3KO4 Jan 6, 2011
  1. S3KO4
    S3KO4 Member
    850
    Hi, everyone
    The cold weather plus age, has snapped one of my rear spring, I found the C shape coil under the car! I think it is a bit less common issue, but was wondering if I could use a coil from an A3 1.8t and does it alter the performance at all?
    thanks everyone.
  2. finesse
    finesse Active Member
    2,805
    quattro springs are different to fwd
  3. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Ive got a set....pm,d
  4. beachbuggy
    beachbuggy Well-Known Member
    1,931
    201
    Hi, I'm fitting coilovers on my S3 this afternoon so will have a pair of springs if it helps? If you're happy to pay the postage and a couple of quid for a beer you are more than welcome to them. Let me know
  5. 3hZ
    3hZ Audi's make the world go round
    27
    So Quattro springs are different to the basic 1.8T? Only ask because my F/O/S coil spring went a couple weeks back, went to a firm called BMS and they got me a spring but slightly different to the original. Had no problems so far.
  6. Welly
    Welly VX220 SC Driver :)
    10,696
    127
    Fronts not so much. Rear suspension setup is very different, as there is a driveshaft coming to the wheel which has to have room made for it.
  7. 3hZ
    27
    Yeah I know, mines the 1.8T Quattro. Just thought i'd ask. Better to be safe than sorry! lol
  8. Welly
    10,696
    127
    :yes:
  9. 666markyboy
    666markyboy Well-Known Member
    1,200
    49
    I changed them on my Quatty last year after it failed it's MOT on one being broken........ they wern't that exspensive as i remember from |GSF and the salesman noted that they were the same item as fitted to the TT
  10. S3KO4
    S3KO4 Member
    850
    cheers, everyone, I will have look at the weekend just to be sure. once I find out, I will let one of you guys know, to take your old springs. I asked because a mate offered me his old ones, and I was not convinced it would be the same, for the same reasons mentioned above.
  11. S3KO4
    S3KO4 Member
    850
    Hi, BeachBuggy, I am only after one spring, to save on weight as well, please let me know how much you are after I will paypal it to you. cheers.
  12. minimatto
    minimatto Member
    66
    I had same problem so have 1 rear spring if you need it, just pay me for carriage.
  13. coyle
    coyle From Show... to GO
    435
    i need one rear spring for my S3.. anyone got one spare?
  14. S3KO4
    S3KO4 Member
    850
    I have a spare one, but it's not at the best condition..
  15. chapmanvr6
    chapmanvr6 Member
    80
    think i also have a spare set knocking about in the garage, as someone else said, very used but in functionable condition.
  16. coyle
    435
    got one sorted from minimatto, it's in the post now, so i should have it tomorrow.. thanks again matt
