Snapped Glovebox Hinge :(
TaylorK Jan 21, 2014
  1. TaylorK
    TaylorK Member
    35
    Just wanted to ask if anyone knows what is the best way to fix a broken hinge on the left side of a glove box?
    Any idea of how much a fix would cost from either Plymouth or Truro Audi?
  2. SAiLO
    SAiLO Well-Known Member VCDS Map User
    1,078
    62
  3. x_eyelashes_x
    x_eyelashes_x New Member
    Just bumping your post as i'm sure you have sorted this by now. My glovebox hinge has snapped on both sides so now the door won't stay on. Can this be fixed or do I need to buy a new glovebox? £40 tops for new box. It's interesting to note that in over 6 years of owning my Audi this is one of the very few problems I have had with it. Having had a Saxo VTR previously which needed constant repairs I see that as a total triumph!!!
  4. Lukeyb
    Lukeyb Active Member
    397
    53
    Mine was snapped on the left side, I took it out, epoxied the pieces back together then got a small metal bracket and drilled about 12 holes in it and screwed in some small twin threaded screws I had, they were about 8mm long x 3mm width. Screwed into the plastic they hold up really strong. I then painted the parts with some of my fiancées nail varnishes that perfectly matched the black and the grey of the flocked interior. You don't know the repair is there as it's the same colour it blends in.
  5. Jackx1
    Jackx1 Member
    126
    15
    I've got the same problem, again with the left side. Probably doesn't help I'm opening it around 6 times a day to pull my phone out of the iPod connection! Why would you put it in there lol!?
  6. andyam
    andyam Active Member
    485
    This happened when I had an a3. I took it all apart....including the barrel...inside has a rubber grommet. I shaved the grommet down so it was much smoother action...and glued the snapped bits back. I closed the glovebox and the n taped the items for 24 hours to let the glue dry properly.
  7. MattWalker
    MattWalker New Member
    My left hinge has just gone sounds like a common problem! However my car is still under warranty from audi does anyone know if this would be covered under the warranty?
  8. Jtaylor
    Jtaylor Active Member
    165
    56
    I tried to get it covered by audi they had none of it, and quoted me £280 for a new glovebox haha
  9. JohnE
    JohnE 2005 A3 Sport 1.6 FSI
    415
    40
    Is it the time of year? My left glovebox hinge snapped a couple of weeks ago.
  10. MattWalker
    Damn! I'm still going to the dealer in the morning to get them to have a look and might just throw a wobbler if they refuse! seems to work for everyone else I ever meet so maybe time I start.
    To top my day off my right dipped beam blew a few hours later! All seems to come at once with me!
