Snapped auxiliary belt on tdi
B5 BIKER Jan 9, 2012
  1. B5 BIKER
    B5 BIKER Member
    266
    The auxiliary belt just snapped on my 99 1.9 tdi.
    It is an AFN engine.
    Anyone know if it's a big job to get done
  2. aragorn
    18,036
    725
    You'll probably need to put the front end into the service position, which requires the front bumper off.
    I'd suggest you look at replacing the tensioner too, as often they'll snap because the tensioner is fubar!
  3. Oranoco
    Oranoco Well-Known Member
    3,834
    364
    Done a Passat with the 1.9TDi without puling the front forward, found a reasonable amount of space to work in really.
  4. aragorn
    18,036
    725
    Yeh passats have a fair amount deeper nose than an A4 though!
    I've done the belt on my 1.8T before and even in service position it was tight.
  5. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Team Akoya TDi saloon Audi S8
    15,161
    1,121
    Same thing happened to my AFN.
    It went cause the tensioner was FUBAR.
    Drop the front end in to service mode, Remove the fan to make it life a bit easier, remove tensioner and redo. :)
    You will need a 8mm allen key to remove the fan.
  6. B5 BIKER
    B5 BIKER Member
    266
    Got it done today, not too much trouble.
    140euro for the tensioner and a belt.
    Seems fine, but the new tensioner seems a little loud.
    Maybe I'm being a bit paranoid, but there seems to be a lot of spring on the tensioner.
  7. aragorn
    18,036
    725
    how much?!
    The tensioner i last baught was about 30quid!
  8. B5 BIKER
    B5 BIKER Member
    266
    I know!!
    You lads are spoiled in the uk with choice.
    Normally I order stuff over on the net, but this was unplanned and I use the car for a 120 mile round commute every day.
    What do you do?
    Normally I buy on eBay or from German parts direct, is there anybody else you would recommend for general parts
  9. aragorn
    18,036
    725
    All German Parts are who i usually use. Dont know if they'd post to ireland though?
