snapped 2 turbo to manifold bolts
Joshstan Aug 6, 2014
  1. Joshstan
    Joshstan Member
    180
    17
    Driving home from work today and got a horrid noise from the engine bay luckily I was nearly home and managed to make it back
    Turns out 2 of the bolts from turbo to manifold have sheared off
    Not fun
  2. Scullies
    Scullies Well-Known Member
    1,543
    658
    at least you only have one bolt to remove to get the turbo off :)
  3. Joshstan
    Joshstan Member
    180
    17
    This is true every cloud has a silver lining going to have to get my mate to knock me up a couple of threaded inserts for the turbo though
  4. Joshstan
    Joshstan Member
    180
    17
    I'm ok taking the down pipe bolts off and the tip and stuff but the mounting bracket I have no clue lol
  5. <tuffty/>
    21,689
    4,121
    Single ()13mm bolt through the bottom of the hotside of the turbo... apply heat if you can as they normally weld themsleves in
  6. Joshstan
    Joshstan Member
    180
    17
    Thanks tuffty I can already see this is going to be a pain on the driveway lol but no time like the present
  7. Joshstan
    Joshstan Member
    180
    17
    This is where I'm at right now lol
  8. Scullies
    1,543
    658
    is that a hole in the manifold
  9. Joshstan
    Joshstan Member
    180
    17
    Forgive me if this is a really bad idea but could I drill the 2 out and use an m10 tap to clear a thread out?
  10. Joshstan
    Joshstan Member
    180
    17
    Please tell me that hole lives there!
  11. <tuffty/>
    21,689
    4,121
    Sorry dude... opening yourself to a world of pain... you should be able to undo the last bolt and undo the support bracket bolt then lean the turbo back enough to wind the broken bolts out... double check the thread inserts are flush as they have a tendancy to wind out too... new gasket, new (OE) bolts and don't lose the thick washers as they are expensive
    Yes... its fine...
  12. Joshstan
    Joshstan Member
    180
    17
    That's it the head is coming off I have just noticed this too[​IMG]
    A half eaten cambelt is never good for business so new head gasket and head bolts new manifold new cambelt and water pump (wish I could afford to do the rods) anything else I should be changing
  13. Joshstan
    Joshstan Member
    180
    17
    So that's the remaining manifold bolt the hanging bolt and 2 down pipe bolts off just the remaining down pipe one and should be pretty free
