Snap-On 14.4V 3/8" Cordless impact wrench
Discussion in 'For Sale/Wanted - Miscellaneous' started by TimJK, May 5, 2012.
  1. TimJK
    Offline
    TimJK Member
    May 10, 2011
    418
    [May 5, 2012]
    Used but in great condition
    Impact Wrench Plus Extra Battery, complete with carry case and paper work.
    GRAB A BARGAIN £650 RRP FOR Impact Gun and Extra Battery.
    [TR="class: classList2"]
    [TD="width: 8"][​IMG]
    Description:
    Screen on the motor to keep debris out and the tool running longer
    Heavy duty dual ball bearing motor
    2.5 Amp hour battery packs
    5.0 Amp hour charger
    230 FT. LB. Bolt Break Away Torque (BBT)
    Super Heavy Duty Impact Mechanism
    Ergonomic Over Molded Cushion Grip
    Dual Rail Slide-on Battery Pack
    Patented Super Heavy Duty Impact Mechanism
    Heat Treated Alloy Gears
    Oversized Trigger
    Glass Filled Nylon Housing
    Cushion Mounted Motor
    Patented Air Flow System
    One Handed Forward/Reverse Switch
    Versa VoltTM Battery System
    LED Light
    [TABLE="width: 401"]
    [FONT=Verdana, Arial, Helvetica, sans-serif]Product Specifications
    [TD="width: 21, align: right"][​IMG][/TD]
    [TABLE="width: 485"]
    [TD="class: topleftps, width: 200, align: left"]Stock #[/TD]
    [TD="class: toprightps, width: 570"]CTE4410A[/TD]
    [TD="class: middleleftps, width: 200, align: left"]Name[/TD]
    [TD="class: middlerightps"]Impact Wrench, Cordless, 14.4 Volt, Slide-on Battery, 3/8" Drive (Europe)[/TD]
    [TD="class: middleleftps, width: 200, align: left"]Price**[/TD]
    [TD="class: middlerightps"]£375.20
    (excl. VAT)
    £450.24
    (incl. VAT)
    [TABLE="class: classSmallestText"]
    where applicable
    [/TABLE]
    [/TD]
    [TD="class: middleleftps"]Brand[/TD]
    [TD="class: middlerightps"]Snap-on[/TD]
    [TD="class: middleleftps, width: 200, align: left"]Country Of Origin[/TD]
    [TD="class: middlerightps"]USA[/TD]
    [TD="class: middleleftps, width: 200, align: left"]Anvil Type[/TD]
    [TD="class: middlerightps"]Friction Ring[/TD]
    [TD="class: middleleftps, width: 200, align: left"]Battery (qty)[/TD]
    [TD="class: middlerightps"]CTB4147 (2)[/TD]
    [TD="class: middleleftps, width: 200, align: left"]Battery Charger[/TD]
    [TD="class: middlerightps"]CTCFE420[/TD]
    [TD="class: middleleftps, width: 200, align: left"]Battery Type[/TD]
    [TD="class: middlerightps"]Ni-Cad 2.5AHr[/TD]
    [TD="class: middleleftps, width: 200, align: left"]Battery Voltage[/TD]
    [TD="class: middlerightps"]14.4V[/TD]
    [TD="class: middleleftps, width: 200, align: left"]Blow Molded Case[/TD]
    [TD="class: middlerightps"]PB165[/TD]
    [TD="class: middleleftps, width: 200, align: left"]Blows per Minute, BPM[/TD]
    [TD="class: middlerightps"]2,900[/TD]
    [TD="class: middleleftps, width: 200, align: left"]Bolt Break Away Torque, ft. lbs. (N•m)[/TD]
    [TD="class: middlerightps"]230 (312)[/TD]
    [TD="class: middleleftps, width: 200, align: left"]Charge Time (minutes)[/TD]
    [TD="class: middlerightps"]35[/TD]
    [TD="class: middleleftps, width: 200, align: left"]Free Speed, RPM[/TD]
    [TD="class: middlerightps"]2,280[/TD]
    [TD="class: middleleftps, width: 200, align: left"]Free Speed, Reverse, RPM[/TD]
    [TD="class: middlerightps"]2280[/TD]
    [TD="class: middleleftps, width: 200, align: left"]Height, inches (mm)[/TD]
    [TD="class: middlerightps"]9.5 (241)[/TD]
    [TD="class: middleleftps, width: 200, align: left"]Length, inches (mm)[/TD]
    [TD="class: middlerightps"]6.4 (163)[/TD]
    [TD="class: middleleftps, width: 200, align: left"]Sound Pressure Level, dBa[/TD]
    [TD="class: middlerightps"]95[/TD]
    [TD="class: middleleftps, width: 200, align: left"]Square Drive, inches[/TD]
    [TD="class: middlerightps"]3/8[/TD]
    [TD="class: middleleftps, width: 200, align: left"]Tightening Torque, ft. lbs. (N•m)[/TD]
    [TD="class: middlerightps"]150 (203)[/TD]
    [TD="class: middleleftps, width: 200, align: left"]Torque Output, ft. lbs. (N•m)[/TD]
    [TD="class: middlerightps"]150 ft. lbs. (203)[/TD]
    [TD="class: middleleftps, width: 200, align: left"]Vibration Level[/TD]
    [TD="class: middlerightps"]5.1 m/s²[/TD]
    [TD="class: middleleftps, width: 200, align: left"]Vinyl Boot[/TD]
    [TD="class: middlerightps"]CT4410BOOT[/TD]
    [TD="class: middleleftps, width: 200, align: left"]Warranty (battery)[/TD]
    [TD="class: middlerightps"]1 Year[/TD]
    [TD="class: middleleftps, width: 200, align: left"]Warranty (tool & charger)[/TD]
    [TD="class: middleleftps, width: 200, align: left"]Weight w/Battery, lbs. (kg)[/TD]
    [TD="class: middlerightps"]4.6 (2.1)[/TD]
    [TD="class: middleleftps, width: 200, align: left"]Width, inches (mm)[/TD]
    [TD="class: middlerightps"]2.3 (58)[/TD]
    [/TABLE]
    [/TD]
    [/TR]
    [/TABLE]
    [/TABLE]
    [TD="class: toprightps, width: 570"]CT4410APDB[/TD]
    [TD="class: middlerightps"]Impact Wrench, Cordless, 14.4 Volt, Pinned Anvil, Slide-on Battery, 3/8" Drive (U.S.)[/TD]
    [TD="class: middlerightps"]£174.00
    (excl. VAT)
    £208.80
    (incl. VAT)
    where applicable
    [/TABLE]
    [/TD]
    [TD="class: middlerightps"]Pinned[/TD]
    [TD="class: middlerightps"]Not Included[/TD]
    [TD="class: middlerightps"]-[/TD]
    [TD="class: middlerightps"]2.7 (1.2) w/out battery[/TD]
    [/TD]
    [/TABLE]
    [/FONT][/FONT]
    #1
  2. Ads
    Ads
    [Sep 22, 2014]
