Smoke tester for boost leaks !!!!!
AARON77 Dec 1, 2011
  1. AARON77
    AARON77 Well-Known Member
    1,324
    31
    Does anybody know where I can get a smoke tester from???
    I've a few boost leaks but can't find anything obvious :)
    Or does anybody have one I could use ?
    Don't have enough time to fanny around with a garage so thought I'd try and buy one but don't even really know what I'm looking for
    All help would be appreciated thanx lads
  2. sportstractor
    sportstractor Chugger
    2,709
    I think they are a Fair bit of money mate, like 600 plus. Think badger 5 got one fairly recently. Most tuning/development garages will have one, cost me £25 to get mine tested, which just revealed Pcv leaks.
    I bought a tester kit off German eBay, which was just the adapters for pressure gauge and tyre valve which also does the trick, but no smoke.
  3. Westy
    Westy Well-Known Member
    17,443
    1,105
    Have you got access to a compressor? It would be easier to just do a pressure test then a smoke test.
  4. AARON77
    1,324
    31
    How do you go about doing this mate
    As I have access to a compressor
  5. <tuffty/>
    21,874
    4,201
    Can vouch for them being expensive... Bill 'invested' in one... they are not a particularly cheap DIY option to buy for yourself...
    They are brilliant though... :D
  6. AARON77
    1,324
    31
    Ouch 600 il be giving that miss lol
  7. Westy
    17,443
    1,105
    It's pretty basic. you need a bung with attachment to put the compressor on. This goes in one end of the boost system, silicone hose after charge pipe. Then you need a bung for the other end, hose that goes onto the TB. Put 30 odd psi through it and listen for air p!ssing out.
  8. SiGainey
    SiGainey Member
    506
    10
    I have a kit that will be up for sale very shortly, as soon as I get back int he country. It will let you pressurise and check for leaks, but no smoke. PM me if you're interested!
  9. sportstractor
    2,709
    This is what iv got, works great if you have got a silicone tip. Although it does pass through the turbo seals.
  10. AARON77
    1,324
    31
    Thanx for your imput guys
    Spent 3 hours refiting hoses and clips and all is a lot better :)
    From 14 psi to this
  11. NHN
    29,576
    1,779
    Smoke pressure kit is between £7-800 last time I checked & tbh its far better than air based version as such, as you can see immediately where it is leaking, wish I had 1 tbh as I made one up, works fine but for small leaks you could never really find the leak that easily.
  12. AARON77
    1,324
    31
    Tooooooo much ££££££££
  13. Westy
    17,443
    1,105
    Brilliant results mate. I'm only holding 16psi at the moment and I'm sure I have some leaks somewhere.
  14. AARON77
    1,324
    31
    Normally get 22.8 on a good day
    U gonna have to get ya hands dirty dude
  15. Westy
    17,443
    1,105
    Could you hear the air rushing out of the leaks? I used to get 21psi but the track day at bedford last month seems to have loosened the hoses somewhere.
  16. AARON77
    1,324
    31
    I didn't use a tester just pissed around with all the hoses till I got the rite one
    Just got in and it's reading 22.6 :)
  17. Westy
    17,443
    1,105
    All FMIC hoses was it? I need to change over the clips I'm using as I'm not a fan of the T-clamp things I'm currently using.
  18. AARON77
    1,324
    31
    Ive not done a fmic yet
    I've modified the hose unto my throttle body and that was the culprit
  19. Westy
    17,443
    1,105
    Ahh ok mate. I've got my work cut out then! I've got a FMIC, catch can, and every othe boost hose has been replaced!
    I'll get the bumper off one night this week and have a real good look. Cheers.
  20. sportstractor
    2,709
    are you guys running stage 2 plus? because according to vagcom im only seeing 17-18 psi. Dont know who mapped my car
  21. Westy
    17,443
    1,105
    Mine is revo stage 2 software, mapped at Badger 5. Bill mapped mine to 21psi as my old FMIC wasn't cooling the charge air too much and my fuel pump was failing. I'm visiting him in January for a health check and map tweaking now I have a new fuel pump and bigger FMIC so shoul get more boost put in the map.
  22. AARON77
    1,324
    31
    I'm running stage 1 revo but have upped the boost
  23. Mujnu
    Mujnu Active Member
    513
    74
    Anyone know of any places in Birmingham that can carry out a smoke test? Thanks
  24. NHN
    29,576
    1,779
    I know its the expensive route, but audi usually have smoke testers as I've used there's before :)
  25. Mujnu
    Mujnu Active Member
    513
    74
    Thanks for the reply Nigel, do you remember approx how much they charged?
  26. NHN
    29,576
    1,779
    I'll be honest, I got it foc as I know the master tech at my dealer guys due to business etc :)
    But all comes down to hourly charges with audi, a leak test would be 30 mins to 1 hour max, if that as a leak should be very apparent in 5 minutes flat.
  27. Mujnu
    Mujnu Active Member
    513
    74
    Damn, good to know people in the right places lol
    Thanks anyway Nigel I'll see what Audi quote me :)
  28. Nilz
    Nilz Defo worth the wait :) Team Ibis TFSI Owners Group quattro Audi A4 saloon S-line owners group Manual
    11,367
    908
    Whereabout in Birmingham are you?
    I know its not in Brum, but R-Tech in Hinckley defo have one.
    What seems to be the issue with the car (which car is it?)
  29. Mujnu
    Mujnu Active Member
    513
    74
    5 mins away from city centre Nilz
    The car is a 1.9tdi SE 55plate BKC 120,000 on the clock
    I feel as tho there's a lack of power I say that because my mate has the exact same car but in sport and his car feels much more poky (his car has 95,000 on the clock don't know if that is the reason why) and I can sometimes hear wind noise, like wind escaping from somewhere but not sure if that's just my ears lol
    My first diesel so don't know if I'm just being a noob sorry :)
  30. <tuffty/>
    21,874
    4,201
    Have you tried the 8P forum too? you are currently in the 8L section which is A3's to 2003...
  31. Mujnu
    Mujnu Active Member
    513
    74
    Oh woops sorry I didn't realise I'll try the 8p section thanks
  32. A3-Lee
    A3-Lee Active Member VCDS Map User
    938
    226
    43
    Where I work does smoke testing pm me mate
  33. Clart
    Clart Audi S3 Gold Supporter Section Mod Audi S3
    928
    235
    43
    Tuffty found loads of leaks on my S3 last weekend at Bills...
  34. Nilz
    11,367
    908
    If you are still reading this, get in touch with Lee, top bloke who will look after you :)
