Smoke After Idling...
russ3376 Aug 26, 2014
  1. russ3376
    russ3376 New Member
    21
    I have an A3 2005 SLine Quattro 2.0TDI..90K FSH. I left it at a valet parking for two weeks whilst on holiday, there was no excessive mileage, about 15 miles put on it. Since i picked it up it smokes (Greyish or Blueish) quite a bit on setting off in traffic and after idling at lights etc, never did before. New turbo fitted last November, timing belt changed at 45k by previous owner. Any solutions or theories will be appreciated!!
  2. russ3376
    russ3376 New Member
    21
    Could it be excess diesel after being static so long?
  3. Jackx1
    Jackx1 Member
    126
    15
    Potentially, Have you taken it for a long drive since? Maybe a try a full tank of v power and a bottle of redex?
  4. pburv
    pburv Well-Known Member Team Glacier Gold Supporter Audi S3 quattro saloon DSG
    5,199
    10,892
    Any decent valet service really should not be putting any mileage on a customers car.is it possible someone has ragged the hell out of it while it was still cold and killed the turbo. Worst still has someone taken your car and swapped the turbo..:undwech:
  5. russ3376
    russ3376 New Member
    21
    Not taken it for a long drive, did Gatwick to Heathrow on M25 but didn't get over 30!
  6. shadow1993
    shadow1993 Active Member
    428
    51
    You should probably start by asking them why there is 15 extra miles on the car and that you are having problems...
  7. SmithyAG
    SmithyAG Active Member
    414
    61
    Mine did this when the oil was ever so slightly over filled, was fine if driven daily, but left stood for longer it would smoke a bit when setting off in first for a few times. It would clear up and then if not used for a couple of days it would start again.
    It stopped once the oil level was back within the marks on the dipstick though. Was only ever about 2mm over.
  8. russ3376
    russ3376 New Member
    21
    It's going into the garage tomo prob for £££££ of repairs!
    The valet service say that the park is 7 miles away which is fine, I anticipated that
  9. russ3376
    russ3376 New Member
    21
    Collapsed Turbo, fkn gutted. Lessons learned, never do valet parking.....
  10. DarkBunny
    DarkBunny Active Member Team Sprint Audi S3
    497
    112
    43
    Have the garage quoted a reason why this would have happened?
    If it's due to 'excessive wear when cold', then surely you can put this to the parking company and complain bitterly? (Don't expect to get anything, but if you don't ask, you don't get).
  11. russ3376
    russ3376 New Member
    21
    I did complain bitterly believe me! And yes you guessed it no joy at all!.... We don't accept responsibility for mechanical faults... Fkn t****rs
  12. russ3376
    russ3376 New Member
    21
    Well finally it's sorted. Two recon turbos later decided on an OE turbo, costly , but lessons learned. Recon turbos are only as good as the guy reconditioning it. The first blew, the second smoked like a chimney and whistled like a fire engine. My advice buy OE for piece of mind and less ball ache...
