SMIC Installed (& about time too)
Defratos Sep 23, 2006
  1. Defratos
    Defratos You’re Dethpicable!!
    2,232
    Finally installed the SMIC (as it should have been) and managed to feed a cold air pipe for my airfilter, enjoy the pics:
    P.S. Thanks for all the help you guys gave me, it helped a lot with the whole bumper removal and IC installation :beerchug:
    from this:
    To this:
    Cold air feed:
  2. jojo
    28,935
    3,587
    Looks neat Daf, question is, has it improved performance?
  3. Rob W8
    Rob W8 Member
    953
    nice one mate, glad its all sorted now.
  4. PaulRS3
    PaulRS3 Well-Known Member
    1,226
    153
    looks good, I would paint that silver cold air feed trumpet black though, so it dissappears into the black void behind the foglight grill.
    Other than that i hope your troubles have been solved.
  5. Defratos
    2,232
    Performance wise it seems to have helped. 1st, 2nd and 3rd gears seem to be faster (especially around 5k onwards) just need to see how it does on the motorway, and the suction sounds a bit different (like a deeper noise).
    P.S. Does anyone know if I would be able to fit two cold air pipes to the fog lights? Maybe with some wire modification (movement)?
  6. nervus
    nervus Well-Known Member
    1,370
    121
    Of course you could, whats next w4nker lights?:moa:
  7. Defratos
    2,232
    lol, not really, I don't like 'em, why does the Tube or IC look chavi?? :gun2:
  8. Ryanc
    Ryanc Active Member
    1,321
    I got good cooling with the set-up,but major pressure drop.
  9. Defratos
    2,232
    what would be the effects of the pressure drop? and a single larger FMIC would sort that out right?
  10. funkymofo
    funkymofo Member
    44
    pressure drop just means you lose boost pressure.....hence less power. This is because the same equipment (i.e turbo) has to pressurise a larger area than before.
    Imagine being allowed only one intake of breath and blowing up 2 balloons of different sizes, the larger one will obviously have inflated less,or in other words have less pressure inside than the smaller one.
    So no a larger FMIC will not sort it out, it will actually make it worse.
    Ideally you want an FMIC of similar total volume to your 2 standard ones,thus minimising the pressure drop/ increase in lag but improving the airflow.
    Obviously cooler air has its advantages too though, its down to you which you prefer - Cooler air so the power fades less as you drive for long periods of time, or an initially greater bhp output that suffers from more heat soak.
    hope that helps.
  11. Ess_Three
    Ess_Three Active Member
    5,383
    True, true...
    I never noticed any pressure loss with my similar set up...
    Besides, a chipped K04 runs hot...if you keep the air charge cold you can increade ignition advance and make more power than you may potentially loose by pressure drop.
    I would have thought that on a K04 with it's limited volume shifting ability you will only potentially loose peak boost - the sustained boost should be the same but with a possible slight lag.
    So, turn up the peak boost to compensate...and enjoy cold inlet temps...
  12. Defratos
    2,232
    Right, things are kinda starting to make sense. So does anyone have any idea as to what total volume the 2 standard SMICs are? so as to get a rough idea of what size I'll be looking for? Even if you know the forge volume?
