Smelly screen wash
Jules Sep 15, 2013
  1. Jules
    Jules Member
    130
    When I use my screenwash after about a minute it really stinks badly, all I can say is it smells like cats pi##, any one else experienced this if so what is the best way of clearing the bottle out, or is it an easy job to remove and clean it all out?
  2. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group S-line owners group
    3,723
    649
    Remove the passenger side wheel arch liner you will then get access to the pipes / pump so you should be able to drain the system. I use quantum screenwash, get it from TPS they always have offers on oil & screenwash. Link to TPS website Trade Parts Specialists
  3. ei2gfb
    ei2gfb Member
    101
    i had this problem on my old leon, i syphoned out what was in the bottle and pushed what was left in the pipes out by using the stalk till it was empty then refilled with fresh water and rinsed it through again was fine after that
  4. a6_chris
    a6_chris Well-Known Member
    1,883
    160
    Stagnant water, disgusting rotten stuff.
    Audi flushed mine a total of 3 times and it smelt good as new, make sure you regularly use your screenwash to stop it going off.
  5. AlexGSi2000
    AlexGSi2000 Well-Known Member VCDS Map User
    1,464
    199
    Same happened to me last month - the smell was shocking!
    I used the washers til it ran dry then filled up with fresh water, its been fine ever since.
    Funny thing was, the previous time I filled up I used a little Mercedes branded screenwash - maybe it didnt like the car! :yes:
  6. Mike_B
    Mike_B Active Member
    533
    47
    Put some vinegar in - it'll also help clear any build up of limescale. Mike.
    voorhees likes this.
  7. GeoffDunk
    GeoffDunk Well-Known Member Team Panther Audi RS4 quattro Audi Avant Owner Group
    1,301
    391
    This is a common problem and its a culmination of two things that causes this to happen. Putting to rich of a mix into the washer bottle and then not using it quick enough. Using a reduced mix would help and using it more frequently would also help stopping it going stail.
    Saying that, once the mix has gone stail then the bottle and accociated pipe work is already "infected" and to fully cure the problem everything should be cleaned out fully.
    The best way to make sure is to strip it out and fully clean it but you can add vinegar to the system and run through a full washer bottle over the epriod of a couple of hours, luke warm water woudl also help this.
    note: clearign out the stai lmix and refilling would make the smell go away in the short term but becuase the system as already been effected the smell return quicker if not fully cleaned out.
    I've learnt this over the years as all cars will do it and most of mine have. i thought I wasn't putting enough addative in so like many others I added some extra to combat the smell but actually it makes it worse.
  8. Zeee123
    Zeee123 New Member
    If u can bare the smell lol just keep spraying until empty and then refill with nice smelling screenwash
    they do bubblegum vanilla and apple flavour in poundland - very good deal or u can getthe pink stuff from halfords
    but yeah as others say try and clean it out first tthen refill
    my saab had this dirty smell after sitting for months disgusting
  9. GeoffDunk
    1,301
    391
    Really is worth the clean out as once contaminated the smell will return quicker.
  10. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,201
    160
    Buy some false teeth cleaning tablets. Drop them in.
  11. Jules
    Jules Member
    130
    Cheers all for the comments, looks like i will be dismantling it at the weekend then, is it an easy job to remove,,,
  12. boost-addict
    boost-addict Well-Known Member
    1,000
    39
    as said cleaning tablets for teeth or a few drops of bleach in to hot(not boling) water and run the hole tank though.
    then run a tank of water again with a disinfectant like tcp. and then run two more tanks of fresh water.
    this will kill all bacteria and the smell
    but if your going to use bleach. remove the pipes from the sprayer and have the pipes drain in to a bucket. (drop the sprayers in to the bucket your draining into)
    i had to do this on a car that had been sitting for ages. mine smelt like rotten eggs. after no smell
    GeoffDunk likes this.
  13. Turkster
    Turkster Bro.Paul 2.5TDI Quattro Sport
    2,797
    Juse pump all the water out and drop a cup of weak bleach in there,
  14. boost-addict
    1,000
    39
    so a cup of weak bleach is going to touch ALL the sides and of the tank? thats were the bacteria is, at the water line likley not below it.
    just do what i said, itll cost you less then £5 if you had to buy the bleach and tcp and itll work, your then have two house hild products that you will use else were
    bleach you know how to use this
    tco, goos for cuts and cleaning floors and sides etc etc
    a cup of weak bleach isnt going to do any thing, maybe a cup of bleach to the whole tank yes
  15. Turkster
    2,797
    yes and no, its all down to how bad the smell is and how harsh you want to be with the bleach, i have drained my tanks before, dropped a good mug full in there, let it sit over night, then pumped it all through next day and washed off any that goes over the cars paint, then you can also add a drop of TFR into the mix to flush it out even more over the life of the water in the tank,
