smell petrol in oil!!!
allybally Jul 31, 2011
  1. allybally
    allybally New Member
    HI I HAVE AN AUDI A3 2.0 T FSi S line Special Edition, 3 Doors, Manual, Hatchback, Petrol, 2006. ON CHECKING DIP STICK FOUND A STRONG SMELL OF PETROL COMING FROM OIL. ANY IDEAS OF WHAT THIS COULD BE? THANKS, ALLY
  2. warren_S5
    warren_S5 Moderator Staff Member Moderator VCDS Map User
    7,210
    2,487
    Cam follower wear, or fuel pump seals. Mileage?
  3. allybally
    97K MILES DO YOU THINK IT COULD BE PISTON RINGS? WOULD THERE BE ANY OTHER SIGNS? THANKS
  4. paddy
    paddy Audi=No fault code, no idea Team Ibis Audi S3 Black Edition DSG
    5,271
    164
    Dribbling injector, worn rings. Does it blow like a leaf blower out the oil filler cap ?
  5. allybally
    just a bit of steam
  6. allybally
    how much do you think any of these would be to fix?
  7. afcjay
    afcjay Member
    437
    could just be a blocked breather
  8. akash_sky1
    akash_sky1 Active Member
    1,181
    This happened to me, and was going on unnoticed for a while and lead to my turbo blowing :-(..at first it was very subtle so easily missed- no smell etc.
    Mine was caused by worn seals both within the HPFP and within one of the injectors. Got a low mileage set put in my Stattler which cured the problem. Best not to drive the car too much till its sorted ,as your oil's not going to be doing its job properly.
  9. allybally
    are you based in glasgow any garages you reccomend how much to rectify? thanks
