Smallest Wheels on S3
beanoir Sep 26, 2010
  1. beanoir
    beanoir Large Member
    2,171
    31
    As the title says, I was wondering what the smallest size wheels I can fit on the S3 are, does anybody know? I suspect it won't be much smaller then the 18's already on it, if at all.
    Cheers!
  2. sub39h
    sub39h Active Member
    2,502
    S3 shares brakes with the old 3.2 that was available in Sport trim with 17s
  3. beanoir
    2,171
    31
    Thats interesting, i've since read up that 345mm discs (like on the S3) will not fit within a 17" wheel, but then I thought the 3.2 had the same size discs as the S3....confused!
  4. PH1L
    PH1L Gievf Buckets
    3,851
    40
    im sure theres a photo floating around of someone with sport wheels on thier s3 for winter runners
  5. beanoir
    2,171
    31
    well thats kind of what i'm after, winter tyres on the 18s are 170 each, so i was thinking of getting smaller wheels and cheaper tyres!
  6. PH1L
    PH1L Gievf Buckets
    3,851
    40
    i think im just gonna shell out, depends on what set of winter alloys i can find as i need to buy a set of boots for the a3 and the s3 too should be able to delay the s3's set by buying winters and running them early
  7. DeckedS3
    DeckedS3 Well-Known Member
    882
    304
    Isn't the calliper bigger on the S3 though, i'm sure a 17" wheel would be a tight squeeze. Maybe with the right offset they would fit.
  8. Scott
    Scott Well-Known Member
    1,306
    126
    On this thought, does anyone know if the spare is different for the S3 and a 2.0 TDI? As I've fitted S3 brakes I'm worried the space saver won't fit if I need it!
