Smallest wheel size on A3 3.2 S-line quattro?
SuperPuper2000 Jun 14, 2010
  1. SuperPuper2000
    SuperPuper2000 New Member
    13
    Guys,
    I am trying to find out what is the smallest size of the wheel that can be fitted to an Audi A3 3.2 S-line quattro?
    I know it sounds a bit silly and everyone wants to go the other way - to fit larger wheels - but I'm looking to buy a set of wheels for winter use on the snow so if I can fit something smaller that existing 18x8.5 - it will help the grip. However brake discs seems to be quite large and I wonder if anything smaller than 18 inch will fit at all.
    I have tried to look in the manual and asked a dealer - without any success. Dealer told me to look in the manual and manual only list size of wheels that are fitted to the car which is 18s, not the other possible sizes.
    I would appreciate if someone could point me in the right direction with this issue...
  2. SAiLO
    SAiLO Well-Known Member VCDS Map User
    1,078
    62
    Have a look at your fuel tank flap. There's a chart with air pressure values for different wheel sizes on it.
  3. matt_white88
    matt_white88 Member
    254
    If 16" wheels will fit I have a genuine OEM set for sale
  4. IN-A3
    IN-A3 Member
    457
    17 inch is the smallest that will fit the 3.2q . tyre size 205/50 / 17 XL M+S
  5. Jonay
    Jonay Member
    274
    isnt it big rims with thin tyres you want for snow though?
    Idk for sure (could be speaking *****!) but it seems that way would be best, less likely to get stuck.
  6. V6Pete
    V6Pete Now running on Bentley's y'all
    1,491
    Yeah 17's are the smallest size that will clear your 345mm discs and calipers, as fitted to the Sport.
  7. PH1L
    PH1L Gievf Buckets
    3,851
    40
    17 7.5s do just fine for winter weather (granted i have studded tyres for the fronts and flexiwall ice tyres for the rears
  8. crunchie
    crunchie Active Member
    880
    77
    it doesnt even look like 17's will fit over the 345mm discs to me! do the sports not run smaller discs?
  9. -Ju-
    -Ju- Well-Known Member Team Panther VCDS Map User Audi S3
    2,372
    493
    Yep, my old 3.2 sport came with 17's on. Brake discs are the same on both!
  10. PH1L
    PH1L Gievf Buckets
    3,851
    40
    17" fit over s3 discs and theyre even bigger!
  11. xs2man
    xs2man Member
    792
    I would think cost would be the overwhelming factor here also though. Smaller tyres cost less, and winter tyres are pretty damned expensive.
    My guess is that I will be stuck with 18's for my S4 though...
  12. V6Pete
    1,491
    No, they're the same.
  13. PH1L
    PH1L Gievf Buckets
    3,851
    40
    calipers are bigger are they not?, anyway you have your answer
  14. edition
    edition Active Member
    1,426
    Same calipers bar different paint job and an S3 clip....
  15. V6Pete
    1,491
    No, they're the same, just different colour and badge
