Small triangular metal plate on rear door??
Andyb5 Apr 4, 2013
  1. Andyb5
    Andyb5 Member
    68
    Does anyone know if this plate on the rear door is removable? And how easy it is to remove? Thought id ask before I start pulling the door card off and find out it doesn't come off?? Ones side is bubbling pretty bad and i wanted to remove it sand blast it repaint it
  2. Ste_Nova
    Ste_Nova Active Member
    1,223
    47
    it will be... but i bet its one of the first things thats fitted to the door
  3. TrisLC
    TrisLC Member
    334
    Of what I've read I thought this was riveted into place?
    due to that I sanded mind down and wrapped it in some carbon.
  4. aragorn
    18,665
    880
    you can remove it, but its a bit of an **** to get out.
    Ideally you need to slacken the internal door frame from the outer skin.
  5. hades-
    9,482
    646
    pita job but doable
    sand down and pain it on the car or wrap.
  6. Andyb5
    Andyb5 Member
    68
    Cheers sounds like a bit of a mission i was hoping it would come off easy but wasn't optimistic that it would. think ill defo sand it down whilst on the car and i like the sound of wrapping it in some carbon actually will give it a go and post up some pics thanks all
  7. mcleodbz
    mcleodbz New Member
    Done this on my 99 A4. Its actually pretty easy. Roll window down,remove the inner plastic trim, and pull down the foam, you will find the securing nut. Once the nut is removed the part can be wiggled out of place.
    Replacements were around£30-35 from Audi.
  8. 205man
    205man Active Member
    1,072
    14
    i did this on my facelift and yes its fiddly but definately do able, and i didnt have to losen pillar i carbon wrapped mine
