Slugglish A4 2.0 Turbo
Brendan12 Jul 12, 2011
  1. Brendan12
    Brendan12 Member
    141
    I've just bought an A4 2.0 Turbo the weekend.
    It's an 05 plate with 53,000. My problem is it feels very sluggish for a 2.0 turbo. I'm not sure whether its me been used to quicker cars, but it really doesn't feel like it even has a turbo!
    Another problem I have is that it makes a really loud rattling/tappety noise on idle. Really doesn't sound right too me.
    I've had it on VCDS with no faults showing.
    Is it me or could there be something wrong?
  2. ChrisFurlong
    ChrisFurlong Avantageous
    343
    Check your DV. If thats blown, replace it, and then you'll feel the turbo. Even if its not blown, worth replacing to the newer metal style.
    If its still slow, remap.
  3. rowdyboy
    rowdyboy Member
    804
    19
    The idling noise is a trait of that engine, there's quite a few threads on it. It's normal.
  4. Brendan12
    Brendan12 Member
    141
    Which metal style do I need to change it too? Will it be ok with a remap then?
    Ok thanks for the info
  5. Marrow
    Marrow Member
    587
    You need the revised OEM version "D" diverter valve. My diverter valve failed and the car was flat as hell.
    Remap will transform the car mate get it done stock 2.0T aint that quick could just be that depends what your used too?
  6. Brendan12
    Brendan12 Member
    141
    I took it out today and it seemed fine. I think it's just me.
    My previous car was an Audi A3 3.2 V6 and before that a Focus ST running 300bhp. That's probably why I think it's slow lol
  7. goon
    goon Member
    332
    my 2.0t feels slow too even after a remap,no fault codes to show anything wrong either,no hissing of boost leaks but no gauge to show boost,my old 1.8t was quicker and more economical its just that these cars are very smooth and efficient and dont feel fast,had a Focus 280 bhp last myself a totally different animal which was exciting and begged to be driven,that too was more economical.
  8. Marrow
    Marrow Member
    587
    No a remapped 2.0t should feel fast mine sure does and I have owned various quick cars ! I would check MAF and DV if I were you ?
  9. ChrisFurlong
    343
    Yeah I've owned a 3.2 A6 and a 3.2 A4 and the remapped 2.0T feels faster than both of those. It should be faster as well in theory, as the 2.0T is lighter, and has just as much or maybe a few more BHP than a 3.2. You will get the turbo lag, but if your in sport mode you will not notice any.
    My advice, get the revision D DV, get a remap. Then you should be happy. If not, then look into a K04.
  10. goon
    goon Member
    332
    my apr mapped 2.0t quattro accelerates like this,30-50 (3rd) 4.48,50-70 (4th) 6.2,60-80 (5th) an agonising 12.3
  11. mikeyw
    mikeyw Member
    137
    Well 60-80 should be 3rd really. Never really timed mine so I can't compare. It's an odd thing to try explain, but mine feels as fast as it should. It's a bit quicker than my old type-r, but much more torquey.
  12. solaris
    solaris Member
    416
    17
  13. Brendan12
    Brendan12 Member
    141
    Cheers. I think my engine code is BPB which isn't covered there. Will double check though.
  14. ChrisFurlong
    343
    My engine code is BGB, not listed there, and it fitted no problems.
    Give Audi a call, give them your chassis number and ask them to check what DV will fit. If they come back saying revision B, then it will definately fit as its the same design. They should tell you to order a revision D as its the updated version and the B is obsolete.
  15. Brendan12
    Brendan12 Member
    141
    After going out in my mates MKV Golf GTi which is standard, I now believe there is definately something wrong with my car.
    The Golf pulled well in all gears, had bags of power everywhere. My A4 seems so guttless in comparison.
  16. ChrisFurlong
    343
    Get your codes read, and go from there.
  17. OxfordRich
    OxfordRich Collecting Rings VCDS Map User
    112
    9
    ....are you entitled to new coil packs under the "recall" that isn't a recall? I was and it feels better still after those.. more MPG i'm certain (long journeys, 2100 miles a month, plenty of time for comparison!)
  18. Brendan12
    Brendan12 Member
    141
    Ive checked them and there aren't any.
    Yeah it's there getting them done as we speak.
  19. ChrisFurlong
    343
    Did you check for codes using VAG COM or a portable codes scanner?
  20. Brendan12
    Brendan12 Member
    141
    Yeah and it didn't show anything which is why I'm confused. There is definately a problem, it's not just me now. When my old A3 went in for coil packs, I had an A3 2.0 TFSI as a courtesy car and again it was a totally different animal.
  21. ChrisFurlong
    343
    Hmm.... well thats got me stumped then. Might be worth taking it to a VAG specialist and seeing what they say.
  22. ChrisFurlong
    343
    Are you sure its a turbo? Audi made a 2.0FSI non turbo. I'm sure your correct, but it was the only thing I can think of.
  23. Brendan12
    Brendan12 Member
    141
    Yeah and me. I took the Audi technician out in it today and even he agreed it was down on power quite a bit.
  24. Brendan12
    Brendan12 Member
    141
    Well the turbo under the bonnet gives it away slightly lol
  25. Brendan12
    Brendan12 Member
    141
    Just scanned my car with VCDS:
    1 Fault Found:
    000665 - Boost Pressure Regulation: Control Range Not Reached
    P0299 - 002 - Lower Limit Exceeded
    Freeze Frame:
    Fault Status: 01100010
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 85458 km
    Time Indication: 0
    Freeze Frame:
    RPM: 4631 /min
    Load: 77.2 %
    Speed: 104.0 km/h
    Temperature: 79.0°C
    Temperature: 25.0°C
    Absolute Pres.: 1000.0 mbar
    Voltage: 13.843 V
    Any ideas?
  26. mikeyw
    mikeyw Member
    137
    Low boost pressure is what it sounds like then. Leak, faulty sensor or turbo?
  27. Sam W
    Sam W Member
    175
    I'm not sure what value it should be exactly, but 1000mbar sounds a bit low, that would be atmospheric pressure. From that I'd definutely say you've got a boost leak somewhere :(
  28. ChrisFurlong
    343
    Almost exactly the same as I got before I changed my DV....
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 125556 km
    Time Indication: 0
    Freeze Frame:
    RPM: 4437 /min
    Load: 91.3 %
    Speed: 48.0 km/h
    Temperature: 84.0°C
    Temperature: 35.0°C
    Absolute Pres.: 1010.0 mbar
    Voltage: 13.589 V
    So it is your DV. Spend £50, and about an hour and it'll be fixed.
  29. Brendan12
    Brendan12 Member
    141
    Thanks, that was on my list of things to do. I'll get that ordered anyway. Would I not hear it fluttering if my diverter valve was broken?
  30. ChrisFurlong
    343
    No you won't hear anything. The holes are really quite small, but seem to let all the air out! You might hear a little bit more woosh when you upgrade.
  31. Brendan12
    Brendan12 Member
    141
    Thanks I'll get one ordered!
  32. Brendan12
    Brendan12 Member
    141
    Little Update:
    I bought a Revision D Diverter valve and fitted it the weekend. Now I have full boost! I knew the car wasn't right and the valve I had on the car was Revision B and had a huge split in it!
    Thanks for all the advice!
  33. ChrisFurlong
    343
    Knew that would be the problem, its amazing the difference that little thing makes isn't it. Glad your sorted.
  34. Brendan12
    Brendan12 Member
    141
    Yep made a massive difference. A lot happier with the car now! Thanks!
  35. audicruiser
    audicruiser Audi Heaven
    1,865
    I changed mine to Rev D last month. I had Rev C on mine and though it hadn't split, I changed it as I have had it remapped. Remapped 2.0T is how they should be from the factory, well worth looking into... :icon_thumright:
  36. Brendan12
    Brendan12 Member
    141
    Yeah I will be getting it done soon!
  37. Geeba
    Geeba New Member
    Hmmm this is interesting!! - whats the chances of my 06 having the piston type already? - I've had it re-mapped but the power doesnt seem smooth or consistent, is this mod a no brainer, ie do it anyway type thing?
  38. chrisa4quat
    chrisa4quat Active Member
    970
    29
    The fault codes definitely relate to the DV. says on the test plan check as diaphragm is most likely split. i am thinking of changing mine as i have fitted the forge spacer and it doesn't seem to perform as it should.
  39. Brendan12
    Brendan12 Member
    141
    Yeah I changed it to the revision D part and now it is back to how it should be
  40. Geeba
    Geeba New Member
    Could anyone give me an idea where and what to look for? - my 18T was easy it was smack bang on top of the engine... I had a quick look lunchtime but I cant see it... :S
